Question about H&B HP5500V Plasma TV
47" plasma 1080p ... screen went black , sound
Anonymous
    Scholar:
  • 43 Answers
Plasma TV's have a shelf life. By that I mean the screen is only good for so many hours depending on the model. Most likely, you have burnt out the screen and the set will need to be replaced. The good news is, plasma TV's used to be better than LCD but that is no longer the case. You can get a very high quality LCD TV for a very low price now. Also they use a fraction of the power and don't generate all of the heat of a plasma.I'm sure this is not what you wanted to hear but the reality is that ALL plasma TV's do this eventually, and it is something that most salesmen back in the day didn't bother to tell customers. If you have an extended warranty, you may be able to get it replaced.
Posted on May 05, 2011
Testimonial: "Thank you for your honesty... it wasn't what I was hoping for , but it was something I needed to hear... Thanks again !"
  • Anonymous May 05, 2011
    I agree with philliphains but would like to add that LEDs would be better then LCD because they the color and life will last a lot longer then LCD
pikozikipa2
    New Friend:
My 42inch EC-PD2000 takes too long to clear the screen sometimes up 30 minutes what could be the problem
Posted on Oct 07, 2011
My tv had a few small vertical lines for year, then went black completely. Sound still works, but no picture. What part/board am I looking to replace?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 17, 2015 | LG 60pk200 60 1080p Plasma Tv 60pk200
Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
Intermittent loss of picture and sound,
its is flashing 10 times the power button on my 1080p plasma tv
Nov 22, 2009 | Televison & Video
Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
Aug 06, 2009 | Samsung SPN4235 42 in. Plasma HDTV
My 5 year old plasma tv has sound but no picture what could this be?
No picture as in a black screen? or a picture with snow (noise)? If there is no picture at all (black screen) with no menu display when menu button is pressed, then it sounds like the y-sus and the z-sus boards are faulty..These are the boards located usually on the left and right edges of the screen. They are fused and these can blow, severing the supplt to the boards. These boards are used to deflect the electrical charge across the screen. If you have no picture then it sounds like both boards are down
Jul 31, 2009 | LG 42LC2D 42 in. LCD HDTV
HITACHI 42" PLASMA SOUND BUT NO PICTURE COMPLETELY BLACK
it can be the loose connection on circuit board .can you resold the all pcb joints.
i will hlp you.or give it to service proffesional.
nuwan.
Jan 19, 2009 | Samsung HCL4715W 47" Rear Projection...
Philips 30PF9946
1 step can confirm if you can fix this. Press menu. If you can get a menu its fixable if you cant its in need of major repair.
Sep 12, 2008 | Philips 30PF9946 30 in. HD-Ready Plasma...
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
H&B HP5500V Plasma TV Logo
237 people viewed this question
Top H&B Televison & Video Experts
Marvin
Marvin
Are you a H&B Televison and Video Expert? Answer questions, earn points and help others
