Samsung HT-TX75 Home Theater
I have the above Home Theater system which has been working fine until now. Suddenly I have lost the Dolby 5.1 - when I play back movies I do not get the sound of the main actors speaking, although I do get any background music etc. If I change the language, I get that language in 2 CH. Can you help, please?
Thanks.
Ray Tyler
Posted by raytyler on
Grubhead
  • Audio Player... Master
  • 5,700 Answers
Check the speaker connections to the centre channel. Also sometimes the settings of the centre channel can be switched off. If the unit has a test tone system start it going and see if it sends one to the centre channel. If it ignores it then it might be switched off.
Posted on Oct 03, 2017
3 Related Answers
Anonymous
  • 121 Answers
SOURCE: i have a samsung ht-tx75 and it keeps shutting
Protection is very likely caused by an over heat condition, even with the fan working if the receiver is in a very enclosed place that warms up and is not ventilated it will cause the problem. The solution is to provide more ventilation so that the receiver can cool itself properly.
Posted on Feb 26, 2009
Don Hart
  • 127 Answers
SOURCE: my samsung ht-tx75 home theater
It sounds like you have either a thermal problem , or an electronic component fault in the power amp section. If the protection circuit is being activated, which disconnects the speakers so you have no sound, this is like to be the problem. Unless you are a trained technician, you should take it to a repair center. If the repair estimate is larger than you are prepared to pay (unlikely, unless it is a snobby shop) you have to decide whether to replace it with a new or used one.
Posted on Oct 07, 2010
SW86
SOURCE: samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Posted on Jan 27, 2011
Regarding HT-TX75 Whenever a DVD is played I have to go in menu I.e. Sound and turn hdmi "on". But this does not "stick". Have to do again when new DVD Thanks
HDMI audio is going where in your scenario? By default, the audio is assumed to be handled by the HT, not some external device. Does your TV have better speakers?
May 19, 2011 | Samsung HT-TX72 Theater System
My samsung ht-tx75 home theater system shuts off for no reason, any ideas of what it could be?
Oct 06, 2010 | Samsung HT-TX72 Theater System
Samsung ht-c550 dolby pro logic II mode does not work.
2. Select menu
3. Settings
4. Audio
5. ASC
7. Exit the menu
Jul 07, 2010 | Samsung HTC550 Theater System
How can I connect my PS3 to the HT BD2 and get it to play dolby digital or dts audio? Thanks
Use an optical cable and then it should work just fine. Just saw Avatar from my PS3 through the Samsung HT-BD2 and the sound was excellent.
So go and buy an optical cable :)
My problem is to get the BD2 to download updates. It doesn´t seem to work for me.
Apr 12, 2010 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
I have a samsung ht-tx75 and it keeps shutting down every 10 minutes saying protection.the fan is working
Feb 26, 2009 | Samsung HT-TX72 Theater System
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Jan 27, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
TV and Sky hd to samsung HT-Z310
connect 1. cable/satellite box to TV with HDMI. 2. cable/sat box to sound system using optical cable. 3.change box sound setting to optical/dolby.
Jan 22, 2009 | Samsung HT-Z310T Theater System
108 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
