Question about Nokia E5 Cell Phone
I have a Nokia E5 and since two days ago, my phone doesn't vibrate or ring when I receive a message. It still rings when I receive a phonecall but it doesn't vibrate too. I have tried switching it off and turning it on, but now, the small mail icon at the bottom does not even appear when I receive a new message.
Posted by lee_fan_yuan on
Prashant Sharma
    Genius:
  • Nokia Master
  • 1,127 Answers
Hi
I think u done something wrong , Go the factory default setting option and put the password Default (12345) and restore the your default setting..
Posted on May 05, 2011
1helpful
How can i block numbers and messages on nokia e5
The easiest way is to have the phone ring-in only for the names and numbers in your address list. In addition, you can have the phone ring-in for numbers that you specify. Follow the Nokia instructions by CLICKING HERE
1helpful
Does Nokia E5 have a vibrate mode? (I tought the phone would vibrate when in "silent" mode, but it doesn't.)
you must edit your profile settings for vibrate mode. its simple. just select any profile, then personalise then on the ringing type choose vibe. thats it and activate the profile. good luck
5helpful
When i receive a message, my e73 doesn't make any noise. i've taken out the battery several times, turned it off and on, let the battery die, but it's not working. the only thing that indicates...
for it to ring delete all your messages from your inbox and outbox then reboot your phone (turn it off then back off) hope it works for you it did for me:)
2helpful
Not able to put the Nokia E5 phone in Vibration Mode
When you get to your phone's setting, select profiles. Amongst the list of profiles, determine which of them you want to use to activate your vibrate mode.
When you have done that, scroll to that profile, select 'options', then select 'personalise'.
In the personalise sub-menu, you are allowed to set the features of that mode to your desire.
In the ringing tone, select no tone, in the ringing volume, reduce the volume to zero. When you are asked if you want to set the ringing volume to the maximum, select yes/ok.
In the vibrate option, select yes/vibrate.
In the message tone, select no tone.
For other sounds and tones, select no tone.
When you are done, REMEMBER TO SAVE IT.
Then go back and activate that profile.
It is advisable that the profile you use for this though, is your 'silent' profile.
Hope that was helpful?
Have a wonderful day.
4helpful
2answers
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
3helpful
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Message Vibration not working
make sure you have "txt messages" set to ring/vibe not "calls to line 1 ring/vibe"
1helpful
3answers
Nokia 6600 no new message received display
HI Qrasengan,
1) Open the menu, and go to profiles.
2) Enter the general option, and click on personalise.
3) after that, several option appears.
4) some of them are ringing tone, ringing type, ringing volume, message alert tone, vibrating alert, etc.
5) Go to message alert tone and change the tone u want to listen when message is received.
NOte :Only wav or midi formats are accepted as ringing tone. MP3s are not accepted as ringing tones in NOKIA 6600. U need to install a software "mp3 as ringing tone" or "mp2wmaogg.codec" to make mp3 as ringing tone.
If u want that software, send me feedback or reply.
And I will deliver u as email in ur email id.
Sajan([email protected])
May 03, 2008 • Nokia 6600
Nokia E5 Cell Phone Logo
Top Nokia Cell Phones Experts
Ekse
Resolution IT Dubai
Resolution IT Dubai
Oloyede Monsuru
