Question about Sony Cyber-shot DSC-H2 Digital Camera
My Sony DSC H2 camera is going through batteries very fast. What can I do? Thanks Don
Posted by Don04031964 on
Anonymous
    New Friend:
    Problem Solver:
  • 6 Answers
What kind of batteries are you using? If you are using alkalines, yes you will only get about 50 or so shots out of a set. You need to use NiMH (nickel metal hydride) rechargeables. You can get a set with charger for about $25-30 from Best Buy. You will get several hundred shots per charge with them.
Posted on May 05, 2011
My Sony DSC-H2 will not turn on, why ?
Probably the battery is empty. Try charging or replacing the battery, then try again.
Aug 25, 2011 | Sony Cyber-shot DSC-H2 Digital Camera
Am looking for a user manual to suit a cybershot dsc h2 sony camera
Click Sony Support link to download user manual copy for DSC-H2
Thanks.
Dec 25, 2010 | Cameras
When I try to zoom on my DSC-H2 camera it turns off.
Hello
Check the battery because weak battery gives this kind of problem, if it is ok, then it might have internal loosing, need to be technically handled by service center.
good luck
Dec 14, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
SONY H2 does not turn on
You should always use the "safely remove hardware" icon at the bottom of your screen. Now, remove the card and the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jan 09, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
No flash w/code e:91:01 on sony dsh-h2
this is a problem for all sony cameras. just go to the settings and initialize the camera this should get the flash going
Apr 01, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Camera problems
Go to camera Menu and select Initialize, this will Reset your camera to factory default settings.
Jan 08, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Nov 18, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Pre-shooting with sony dsc H2
There's a chance that the settings might have been changed.....Just try after resetting the camera to default factory settings.
Mar 05, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Sony Cyber-shot DSC-H2 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sony Camera Expert? Answer questions, earn points and help others
