Volvo service light 1996-00
850,
S70,
V70,
S80
1996-97,
1998-00,
1999-00
Service reminder lamp must be reset with either a Scan Tool Connected to the Data Link Connector (DLC), or connect a Volvo Rest Tool to the DLC and press the button on the tool to reset.
240
1986-93
When the "SERVICE" is illuminated, reach behind the instrument panel and push the level located between the tachometer and speedometer.
740,780
1986-88,
1988-90
When the "SERVICE" light is illuminated, reach behind the instrument panel and press the button located to the right of the speedometer.
740,
760,
850
w/ Yazaki Cluster*,
940,
960
1989-92,
1986-90,
1991-97
When the "SERVICE" light is illuminated, remove the cap on the face of the instrument panel between the clock and the speedometer. Insert a thin-bladed tool into the cavity and press the reset button.
*Odometer above the speedometer needle.
All Models
1999
Press and hold trip odometer reset button. Next, turn the ignition key to the run position KPII (not the start position). Wait 30 seconds or until service light begins blinking. Turn the ignition to off position. Release the Trip Odometer button.
850
w/ VDO Cluster*
All Years
To reset the Service Reminder Indicator, turn the ignition on while the engine is not running. Access the diagnostic unit located on the left fender well under the hood. Connect the single wire plug to terminal #7. Press the reset button four times shortly. When the LED glows, press the button once. When the LED glows steadily again, press the button five times. When the LED glows steadily again, press the button once. After the LED gives a couple of rapid flashes, the system is reset. Unplug the connector and turn the ignition off.
*Odometer located below the speedometer needle.
Thanks, I'm certain the 12V is connected. I metered it and its fine, I have it connected to the yellow cable. The radio stations aren't resetting but maybe those are stored in flash.
I have a new problem though. At the moment when I turn the ignition the cd drive whirrs up, the lights on the radio come on and then go off and the radio won't turn on. I'll have to check fuses later.
One of the wires from the firewall is just 5V whether the ignition is on or off, I assume this isn't needed and is for an advanced feature like remote control power, or powered aerial.
Do I just need 3 lines to power the radio, constant 12V, ignition toggled 12V and ground?
Here is the link to the install guide
http://resources.jvc.com/Resources/00/00...
Appreciate your help greatly.
Correction, my last post should have read I have the constant 12V connected to the red cable of the radio harness and the ignition toggled 12V to the yellow cable of the radio harness
