Question about One For All URC-3021 Remote Control
I need to know how to find tv codes by code search
Posted by fcombs1111 on
    Top Expert:
  • One For All Master
  • 76,466 Answers
Hello
[1] On the remote control, press TV once.
[2] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[3] Enter 9 - 9 - 1.The LED will blink twice.
[4] Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, UP or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
[5] To lock in the code, press and release SET.The LED will
blink twice.
[6] To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
OK.
Posted on May 05, 2011
4 Related Answers
AvioriX
ExpressFiX
  • 689 Answers
SOURCE: PHILIPS CL034 UNIVERSAL REMOTE
Hi
I am attaching a link that you can obtain free user's manual which contains step by step instructions and code list. Click on the link below
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Good Luck
Posted on Nov 10, 2008
Anonymous
SOURCE: need codes for daenyx tv
need ikon tv cod
Posted on Mar 24, 2009
Anonymous
SOURCE: need instructions to program, and need to know where code search button is, lost my manual book in recent move. thanks
i need to program my radio shack 3 in 1 remote but lost the instructions
Posted on May 25, 2009
Anonymous
  • 86 Answers
SOURCE: How do I code search my RCA model RCR311W Remote
The Auto Code Search and Entry Method enables the remote
to automatically search through all the codes in the Code Lists
for the one that operates your component.
Note: The Auto Code Search method may take a
long time because the remote searches through all of the codes
in its memory for the code that operates your component.
1. Manually turn on the component you want the remote to
control (TV).
2. Note: If you press an invalid key during the Auto Code
Search, the remote does not respond and the illuminated
ON•OFF key does not blink.
3. If you do not press a valid
Auto Code Search key (TV), the search times out
after two minutes. When the search times out, the illuminated
ON•OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
4. Press and hold the component key
(TV). The illuminated ON•OFF
key turns on and remains on.
5. While holding the component key
down, press and hold the ON•OFF
key. The illuminated ON•OFF key
turns off.
6. After holding down both keys for
three seconds, the illuminated
ON•OFF key turns back on.
7. Release both keys. The illuminated
ON•OFF key remains on.
TIP: Throughout the programming of each key, be sure to
keep the remote pointed at the IR sensor of the component you
are currently programming the remote to control.
8. Press and release the PLAY key,
then wait five seconds to see if
your component turns off. If your
component does not respond,
continue to press the PLAY key
every five seconds until your
component turns off. Each time you
press the PLAY key, the illuminated
ON•OFF key blinks and a block of
10 codes are sent to your component.
This process continues until all of
the codes in the Code Lists have
been searched. (If your component
has not turned off after all codes have
been searched, the illuminated
turns off. The Auto Code Search
Entry method is exited.)
9. When your component turns off, you
know the correct code is in the last
block of 10 codes sent. Press and
release the REVERSE key. Wait two
seconds to see if your component turns
on again. If your component does not
respond, continue to press the
REVERSE key every two seconds until
your component turns on again. This
will isolate the correct code in the last
block of codes sent. Each time the
REVERSE key is pressed, the
illuminated ON•OFF key blinks.
Note: If you accidentally press the
REVERSE key after your component
responds, press and release the
FORWARD key. Then, wait two
turns off again.
10. Once your component turns on, you
have found the correct code. You
must save the new code by pressing
and releasing the STOP key. The
illuminated ON•OFF key turns off.
You must press the STOP key
to save the code or the correct code
will not be stored!
11. To confirm that the component key is programmed with the
correct code for maximum functionality, test the component.
Attempt to control a variety of the component’s functions
with the remote. If some of the features of your components
do not work, try programming the remote with a different
code in the list until you find the code that allows the remote
to control the majority of your component’s functions.
Different codes can provide different levels of functionality.
Posted on Sep 11, 2009
What to use a rca universal remote butdont know the code
3 Ways to Program an RCA Universal Remote - wikiHow
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowJump to Remotes Without "Code Search" Button - Using Brand Code Search ... (for example, many stereos don't support remotes). ... in this article to program the remote,but ... If you know the exact code that you need ...
Program an RCA Universal Remote Without a "Code Search"
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a "code ...Don't let go of the TV button. ... Please tell us everything you know about.
Programming the RCA RCRN04GR Universal Remote
Dec 25, 2015 | RCA Televison & Video
What to use a rca universal remote but i dont know the code
2 Easy Ways to Program an RCA Universal Remote Us
Colby tv codes for charter UR4U-MDVR-CHD2 remote
There is no setup codes for this TV with this remote control. Do a code search. If any code matches, you can win. If you want to know about code search method, check this link.
Jan 12, 2013 | Coby 40 TFTV4028 LCD TV
I need to know how is the code of OLEVIA MODEL 237-T12..., i need to put that code in my control remote..!!! thank you
if you have a universal remote just check if your tv is listed in the manufacture menu.if it does look for the code beside your tv brand.it could have more than one code so you have to try all of them.if you find it then first turn on the tv manually. you press down the code search on the remote it will stay light release the code search button.press and release the tv button on the remote.enter the code found on the remote chart that is pertaining to your tv by entering it on the remote manually. aim the remote on the tv push the the on off button try this with all the codes untill your tv cut off. if your tv does not appear on the remote list use the manual code search.which is.. first turn on your tv manually press and hold the code search button until the indicator light illuminates.trhen you release it.press the tv button on the remote.the indicator light will blink and stays on.aim the remote on the tv and press the on and off button continously until your tv turns off you have to do this up to 200 hundred times continouslly.when your tv switch off press enter to store your code.
good luck/
Mar 04, 2011 | Televison & Video
Lost manual need to know how to set remote to tv
You need 2 things to program your remote to your TV, the programming instructions and the correct code for your TV brand. There are 4 different methods for programming the remote, which are explained in the following videos:
Direct code search:
http://audiovox2.info/videos/rca_acc/new_intro.html
Auto code search:
http://audiovox2.info/videos/rca_acc/auto_code.html
Brand code search:
http://audiovox2.info/videos/rca_acc/brand_code.html
Manual code entry:
http://audiovox2.info/videos/rca_acc/manual_code.html
Sorry, but there is too much information to list it all here so it's much easier if you watch the videos. You will need to have Adobe Flash Player installed on your PC to view them:
http://get.adobe.com/flash/
Please note, your remote is fairly old and if you are requesting this information in order to program your remote to a NEW TV, the code searches and manual code entry are NOT guaranteed to work.
If the code searches don't work, it's unlikely that your remote can be used with your TV, but if you need to use the manual code entry method, you can find the codes for all TV brands here:
http://rcaaccessories.com/remotefinder/?sku=RCR311B&productType=TV
Regards,
BElectric
Nov 18, 2010 | RCA RCR311B Remote Control
RCR460 Remote Control: I need to know how to program my rcr 461 to my tv....
Please follow the below steps to set up your programme
Direct Code Entry:
  1. Find the code your device.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Enter the 3-digit code number.
  5. Release "CODE SEARCH".
  6. With the device on, press another button to test. If it does not work, repeat steps 1 thorugh 5.
Code Search:
  1. Turn on the device you wish to control.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed(VCR,TV)
Make name(toshiba,sony)
Thanx
May 16, 2010 | RCA RCR460 Remote Control
How do i get it connected to the tv? and how do u use codes i dont know how to use the codes
To get your Innovage Jumbo Remote Control connected to your TV you need to program it with control codes specific to the brand of your TV. If you know the brand of TV you have you can look up the control codes for that brand in a chart. If you don't know the brand, or if the codes in the chart do not work on your TV, you can perform the auto-search function of your remote to find the codes that work.
To search for the control codes that will work on your TV, follow these steps:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 08, 2009 | Innovage Jumbo Remote Control
Lost codes to program my remote
im trying to connect to my tv and need the codes....its a toshiba tv
Oct 13, 2008 | RCA RCR311B Remote Control
Need code
try code 238, if it does not work you will need to try the code search.
1) turn on tv
2) press and hold "code search" until indicator light comes on
3) release code search
4) press and release "tv", indicator light should blink once
5) aim remote at tv and press the power button until the tv turns off (you may have to press it 200 or so times)
6) once the tv turn off, press enter on the remote
Nov 17, 2007 | RCA RC-U703SP Remote Control
Programming my URC-3021
Magnavox 0054, 0706, 0030, 1454, 1254
Symphonic 0180, 0171
Emerson 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
CH, or PLAY).
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 05, 2007 | One For All URC-3021 Remote Control
One For All URC-3021 Remote Control Logo
395 people viewed this question
Top One For All Televison & Video Experts
Nick Charalampakos
Level 1 Expert
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
