Question about Frigidaire Washing Machines
Need part # for LTF2140E53oor handle for - Frigidaire Washing Machines
Posted by mktt on
Jeff Rockwell
  • 5,911 Answers
The model number for your washer is actually LTF2140ES3. Parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The door handle part number is 134412860 and is listed as item 46 under the "Cabinet/Top" parts listing. If you are referring to the door LATCH (vice the handle), the part number is 131763202 and is listed as item 8 under the same parts listing.
If you need further guidance, please post back and let me know. I hope this helps you.
Posted on May 05, 2011
How do I remove the door handle?
Brand and model would really help. Some handles have thin metal inserts that need carefully pried out with a small blade and then you will see the mounting screws inside the handle. Other handles have small allen head set screws in the side of each end of the handle that need loosened until the handle pulls off. Other handles have no screws showing but need pushed upward to release them from the mounting studs. Can't give the exact procedure without a model number.
Jul 12, 2015 | Refrigerators
Need to get handle off of pantera sand filter
You need to remove the "key assembly" before removing the handle. The key assembly is the lid, handle and diverter which all come out in one piece after taking the bolts out around the lid.
Once the assembly has been removed, you need to compress the lid down toward the diverter to allow the handle to move freely. At that point the handle pin, which connects the handle to the diverter may be removed. Note the position of the handle's pointer and the open slot on the diverter. When reassembling it is important that they are in the same position. If not careful the handle will be 180 degrees off.
Its a good idea to go ahead and change out the diverter o-rings and bearing on top of the lid (that the handle slides upon while turning) while you have it open.
Mar 13, 2013 | Pool & Spa
How to fix the door handle and lock on a 1999 mercury mountaineer
Not sure which handle you are talking about but if its the inside handle it may just have come loose, you will need to check the bolt or it may have broken at the hinge , same with the outside handle if its loose it may just need tightening or it may have also broke at hinge area. you will need to remove the door panel to get a better look at things.
Dec 06, 2011 | Cars & Trucks
The handle on the front of frig is loose....how do I tigthen.
Hi.
The handles are retained by tiny screws. You will need an allen key to tighten the screws. If the handle is damaged you will need to replace the part. If you need to replace the handle buy the single handle rather than the kit. The kit will be more expensive.
Please refer to video and diagram below. Click on the diagram to enlarge the picture:
Here replacement parts for this model.
Regards.
Ginko
Aug 19, 2011 | KitchenAid Superba KSRG25FK Side by Side...
I have a single handle Danze shower. I can't turn on the water. The handle just turns all the way around.
sounds like handle is not engaged....pull handle...may need allen wrench...after handle is off see if you can turn water on with pliers...should go from right to left...if that works...install handle and tighten with allen wrench....handle should set from off area...see if handle is stripped out or not on proper...if need new handle...pick up at lowes or plumbing supply...good luck
Jan 16, 2011 | Danze & Single Handle Tub And Shower...
Need to install a door handle for 1998 hyundai
yes remove the panel, unhook the linkage one for the lock and one for the latch remove linkage from the handle not the latch, then remove blots holding handle then remove handle from outside the door, you will have to swap the lock to the new handle and then install new handle.
Nov 29, 2009 | Hyundai Motor 1998 Accent
How do I remove the handle to check the Cartridge on a Danze D307456 Bannockburn Widespread Double Handle
You need to hold handle lever and unscrew the bottom escuteon plate you may need a small strap wrench it will turn counter clockwise. On some older models there was a set screw on the handle which you would use an allen wrench
Nov 13, 2009 | Danze D307456 Bannockburn Widespread...
I have a susuki forenza and I need to replace the driver's side door handle. I already have the new part (door handle).
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can remove the inner door handle and replace with new one. If it's your outer door handle, pull back the weather seal and disconnect the linkage to the outer door handle and then remove the bolts securing the outer handle to the door
Oct 23, 2009 | 2006 Suzuki Forenza
I am trying to fix a door handle that will not open from outside
Turn the window handle to where you can see a small 1/2" slot rt at its base where it meets the panel.you'll notice a small brass v shaped clip,you'll need hooked pick or something simular to hook this clip and pull it out of its slot,this release's window crank handle. Once this is off the rest of panel is held on by plastic panel clips that pull loose by pulling panel outwards from door ,and also by a few various screws. once panel is off temp. slide window crank back on and crank window all the way up. You then should have clear view of outer door handle. Handle has two rods attached to it,one for lock assy., one for latch release.This is the one you'll be looking at.Most likely you will find rod has came loose due to broken retainer clip at handle,or casting on handle itself has broken off.If clip is broke you can buy new clip at dealer or at some autoparts outlets,replace and reattach rod(make sure rod locks into place).If handle casting is broke will need handle replaced.It is held in place by two 10mm bolts,two rods preeviously mentioned. If handle is body color matched will need color code(on door jam sticker)to order handle from dealer to match.Lock assy will need to be transfered to new handle,it is held in by two spring clips.You notice two holes one on each side of lock,you will need to push release clips inwards through each hole to release lock and slide it out.to install just push down into newhandlle until clips engage. Let me know if you run into problems. Good luck and if this was able to help you please leave me some positive feedback. Thanks and good luck, Joel
Oct 12, 2009 | Honda Civic Cars & Trucks
Need to replace drivers side door handle?
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. If it's the inside handle, you'll need to disconnect the rod from the back of the handle. If it's the outside handle, you'll need to pull back the weather seal and use a socket wrench (10mm or 11mm I believe) and remove the mini bolts holding the outer handle on, be careful as I believe the lock cylinder is also held on by the same bolts. then you should be able to pop off the handle (disconnect the rod first)
Aug 21, 2009 | 1991 Chevrolet S-10
Washing Machines Logo
294 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
