Heating & Cooling Logo
Posted on May 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I had a new American Standard ACONT800 termostat installed. Our old thermostat had a settings for "system: heat, aux heat, cool, auto, or off" The new Amer Standard themostat has all but 'auto' for system. The manual says "auto, (if enabled). My question is, how do I enable it? can't find it anywhere on the internet
Joe A H.
Level 2:
Sergeant:
  • Expert 185 Answers
  • Posted on May 05, 2011
Joe A H.
Expert
Level 2:
Sergeant:
Answers
185
Questions
Helped
58227
Points
549
INSTALLER SETUP
1. Press SYSTEM.
2. Press and hold these two blank buttons until the
display changes. You will have 5 buttons at the bottom of the stat..... Press the two blank button on either side of the middle blank button till the display changes and then scroll down to 0300 and use the up and down arrows to change from 0 to 1 push Done and you should now have Auto.....if you have other ??? look up a Honeywell Pro 8000 stat it will have the same features...
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1871.pdf
Adaptive intelligent recovery: how to disable the feature in American Standard ACONT800
Google tcont800 installation manual. option530 should be 0 not 1. Press system button, 2 and 4 square hold until screen changes, option 530 --0
I have an American Standard unit showing error 91
Had error code 91 on Trane XL19i thermostat. Heat season on duel fuel system. Repair tech said board is bad ($963) and transducer ($1000). Unit is 3 ton 12 years old. Does it make sense to repair or put in a new unit?
Tran 4ton heatpump aux heat willnot come in auto heat mode
Could be cupel of reason #1 if you just installed new thermostat has to be programmed for two heat one cool heatpump. #2 you have lost a wire usealy white on w2 and black on E .or if you have a very old t-stat might be time to replace sounds like old t-stat
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
What does the "auxillary heat"
Auxiliary Heat is used to turn the electric heat strips ON, If the heat pump is not working. Or if the heat pump can't bring the space temperature up to Set Temperature it will display Aux Heat ON....... Assuming you have a Heat Pump System with Auxiliary Electric Heat as Back up...... If the tech didn't install a jumper wire from AUX to W on the subase which is in back of the Display on the Thermostat.....you won't get Auxiliary Heat if the Thermostat is set for Auxiliary Heat. Other wise the thermostat will turn the heat pump on first and then the electric heat (Aux Heat) if it needs it to satisfy the set temperature....... Hope this helps
Just installed Honeywell RTD7500d thermostat to replace Batstat239 (which seemed to have faulty temperature gauge - it would keep pumping both hot and cold past the set point indefinitely). I followed the...
Wiring seems right, but it needs to be wired like the original tstat. Meaning if W was connected to w1 on the old, that's were it goes on the new. If it was on aux heat then your wiring seems correct. If its operating the aux heat "on its own", then that's were your issue is at.(?) Also, there is a configuration menu in the new tstat. It needs to be set up for your system, heat pump, 1 cool, aux heat or 2 heat 1 cool, O should engage the reversing valve(RV=O). If you didn't write down or pic what you started with, it will be tough for you, and us, to wire your unit correctly. And there is no factory installed fuse on the outdoor. The indoor will(should) have a 3 or 5amp "blade" fuse, (car fuse but not the new smaller style, the 80's to 90's style). Its on the indoor circuit board. Hope this helps!
Removed my non programable Honeywell RT 5220D replaced it with a Honeywell RTH6350D to run my Goodman Heat Pump. First I labeled the wires then connected wires as follows: AUX, G, C, O/B (orange wire)...
Leave the factory jumper between R & RC. Connect the wires to the new stat just as you have them labeled. Use a piece of thermostat wire to make a jumper from AUX to E terminals. Your new thermostat should give you instructions on how to access the installer set up. You are going to set it up as heat pump with aux. I see this is 2 days old but if you need any help let me know.
The heat pump stays on to 20 deg (outdoors) and the burners will not work till the temp is under that leaving the house at a max 65 deg, I beleave the heat pump should true off around 30 -35 deg ? then the...
Remove the cover of the circuit board and controls on the outside unit. Some units have a thermostat that allows you to set the temperature at which it switches to the second stage of heat. Set that for about 34 degrees.
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
3answers
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Top Heating & Cooling Experts
Paul Carew
john h
