Question about Canon A3300 IS Digital Camera
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
Posted by just4nell on
Nipuna Gunarathne
    Scholar:
  • 96 Answers
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
Posted on May 05, 2011
1 Related Answer
  • 102366 Answers
SOURCE: trying to install a canon powershot A480 digital
Having gone over a month without a response, I assume this is no longer a problem.
Posted on Aug 20, 2010
MAC show "insufficient resolution" when
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Jun 25, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
I cannot install the canon software on my macbookpro because apparently there is 'insufficient screen resolution.' how can i fix this?
this may work r u trying to look at your pictures on your computer, if so you can get a card reader and put ur sound card into that and plug the usb cable that comes with the card reader into mac and then you can see your photos, i have a mac book and thats what i did and you have iphoto as a way to work with your pictures if this helps..
Nov 28, 2009 | Canon PowerShot SD1200 IS / Digital IXUS...
Screen resolution to execute digital camera solution disk is not sufficient
Go to start/control panel/display/settings/adjust your screen resolution to high and then install.
Once installed, change your screen resolution back as low or high as you wish.
Apr 20, 2008 | Canon PowerShot S5 IS Digital Camera
Can't install the solution disk
Click on "Start" lower left corner of your screen, and select "Control Panel". Then double click the "Display" icon. Then click on the "Settings" tab.
Slide the screen resolution slider bar 1 click to the right to select 1024 x 768 resolution. Then click OK. You should be able to install it now.
Apr 12, 2008 | Canon PowerShot A450 Digital Camera
Canon powershot sd850 is digital elph
Hi
No, it means the screen resolution for your computer. These days most computers should have their resolution to 1024x768. If you don't know how to change it ask somebody who knows a little about computers to help, its not a problem with your camera.
Thomas
Mar 01, 2008 | Canon PowerShot SD850 IS Digital Camera
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Sep 13, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon A3300 IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
