Question about Acer NSK8458AN Keyboard
Cant find @ symbol tried shift and alt and number 2.bought in canada im now in uk
Posted by daniel88murp on
Matt Larose
  • 340 Answers
Being Canadian I can assure you that the @ symbol is produced by holding down the shift key and pressing the number 2. This keyboard may have a different setup, or you may need to change your language settings on your computer from Start>Control Panel.
Alternatively, you can open a virtual keyboard from Start>Programs>accessories>accessibilty>virtual keyboard
Posted on May 04, 2011
I just had my computer cleaned...now I cant get the AT symbol. I used to press shift and 2 now it gives me " instead...
It could be that a key is stuck on your keyboard. Try pressing all of the Shift, CTRL, and ALT keys a couple times. Try again. Also, try rebooting if that doesn't help.
Oct 31, 2014 | Acer Computers & Internet
How do i access the characters/symbols
you need to press alt and insert ascii char code for the marks.
Oct 17, 2008 | GE USB Retractable Number Pad HO98462
Where is the pound symbol?
The pound symbol is the on 3 key on your keyboard. So you just need to press shift+3 to get #.
May 03, 2014 | IBM Lenovo ThinkPad T400 7417 Notebook
My @ symbol is stuck on the " sign. I do not have an ALT GRA key. I have an ALT CAR key and and ALT key but neither seems to help. I've tried hitting the Fn key and 2 at the same time but still no...
Sounds like your keyboard in in UK mode, but is labeled for US. Or the other way.
In a UK keyboard, Shift+' (the key which is two spaces to the right of "L") should give you an @ sign.
Depending on your Operating System, you can use the CONTROL PANEL and REGIONAL SETTINGS to set the keyboard to be a USA keyboard, and then Shift+2 will give you an @ sign.
http://en.wikipedia.org/wiki/Keyboard_layout is a good reference for keyboard layouts.
Apr 17, 2011 | Toshiba 310CDT Keyboard
Cant print the symbol @ on my note book
Press SHIFT-2
if that isn't working , press and hold the ALT key, and type 64 on the numeric keypad then release the alt key.
If method 2 works, and method one doesn't, check your keyboard layout, and switch it back to US when you get the chance.
Also, see if the number 2 in the top row works at all...if not, the keyboard might be defective.
Feb 22, 2011 | Acer Aspire One Netbook 8.9" Notebook
Trying to get the euro symbol to work on an acer aspire netbook
Try Alt Car and then the Symbol or Alt Gr
if thats not working change the keyboard layout language to Eng canada its then try Alt + Gr Or Alt + Car
Nov 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
My key board dose not work right can not make the @ symbol with the key right key it make the @ symbol with the number 2 key I need help to fix this proble.
Maybe you haven't press SHIFT key then @ key at the same time.If the problem still occur. Try the alternative way below
press ALT 6 4
to do this hold ALT then press 6 and 4...the number should be press at the numeric keypad and be sure the numlock is press or ON.
Jul 19, 2010 | Computers & Internet
I have just bought an Inspiron laptop and can't type the "at" sign....i've tried ctrl + alt and the 'at'above the 2 also the ctrl + alt on the right of the keyboard....but can't managed to do it. Pls...
if you are in the USA the keyboard layout should be ok.
to check it go to
-start
-control panel
-regional settings
-keyboard layout.
if the layout is for UK then the "@" symbol will be where the " is.
That is shift+apostrophe
Jul 03, 2010 | Dell Inspiron 6400 Notebook
ViewMate Keyboard: when I press shift 2 I get inverted comma. donot w...
you need to change the keyboard lay out install US if the machine is from US and UK if bought in the UK goto regional settings etc
May 16, 2010 | ViewSonic ViewMate Keyboard
When i press shift '' it should be an @ symbol
Yau have selected another language of keyboard - german languages
On English if you press shift + 2 rezult @
On German if you press shift + 2 rezult "
Please change you keyboard to english folowing this steps:
Press on the keyboard taskbar if it is present and select EN like this:
611c1b5.jpg OR
Press Left Alt + Shift once an see if on your taskbar the symbol DE is change with EN (english layout) .
OR
Do sequence: "My Computer, "Control Panel,""Regional and Language Options"
Click on "Languages"
Click on "Details"
In "Installed Services" click on "Keyboard"
See if your English keyboard is present.
Click on "Language Bar"
Click on "Show the Language Bar on the Desktop"
Click on "Advance Key Settigs" and see what combination is use for change "Between input languages" - by default is Left ALT + Shift, but you can change this.
Click OK and exit "Regional and Language Options
Press Left alt+ Shift to change between DE keyboard to EN (this is displayed on the rigt bottom taskbar near by clock, volume...)
Feb 25, 2010 | HP Computers & Internet
Acer NSK8458AN Keyboard Logo
166 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
