Question about Kirby Generation 3 Bagged Upright Vacuum
I just recived a free Kirby G3 vacuume. the only problem is the on/off switch dosen't work and someone took it apart before i got it. all of the parts are there as far as i can see but they did not label the wires I need a diagram to be sure that i replace them correctly. Where can I find one?
Posted by a_ray32 on
5 Related Answers
Marty marty
  • 883 Answers
SOURCE: Kirby G3 won't run
sounds like brushes not being pressed down to the commutator shaft. pull out brushes and clean the brass brush guides and then apply a light coat of grease to brushes. however, what exactly do you mean by "the fan is OK"?
Posted on May 29, 2007
Anonymous
  • 35 Answers
SOURCE: Kirby G6 won't turn on.
If the brushead is removed,there is a safety switch which prevent the machine from operating if the brushead is removed or not installed correctly.Either this switch or the main power switch could be the culprit,as well as the cord.
Posted on Dec 16, 2008
Anonymous
  • 3 Answers
SOURCE: vacuum won't switch on;got it apart;cord ok;need wiring diagram
Its a great idea to write on paper how its connected . So it helps with dis assembly & reassembly . I tried a Internet search . Looks like it'd cost money for a service manual. Though. I found a Kirby Spares Website that could help. Although it doesnt have Document downloads with repair help. There are spares & there is a telephone number for an engineer available during office hours. That you could ask for repair help. With wiring connections for your Kirby G3.
http://kirby-owners-club-shop.com/faqs.htm
The Engineers Telephone Number is 0845 388 9301
I repaired my Parents Kirby Heritage some while ago. With a new set of Brushes. Bulb Repair.
They are a Great Machine. Bit Expensive. Though Tough & Well Made !
Gary
Posted on May 24, 2009
RockyNR1
Rocky
  • 324 Answers
SOURCE: Kirby Generation 3 Pictorial or wiring diagram
Go HERE. This should be more than enough info.
Rocky
Posted on May 30, 2009
VacuumRepair
Chris Jones
  • 438 Answers
SOURCE: i need to replace power supply. where the cord
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
Posted on Mar 21, 2010
Switch on Kirby G3 does not work
to tricky to self repair, you have to strip the motor down to replace speed switch, contact your local kirby service centre
Jan 11, 2013 | Kirby Vacuums
Where to find free manual for kirby g3 vacuum and shampooer?
http://www.goodvac.com/articles.asp?id=135
Hope that helps,
Chris J.
GoVacuum
Apr 06, 2010 | Kirby Shampooer Shampoo Hose G3 Ultimate...
Replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Dec 31, 2009 | Kirby Vacuums
Kirby G3 shampooer
The Kirby shampoer lays a layer of dry foam on the surface of the carpet and then scrubs it back off with a rotating brushroller. You can get more details of how to use one here...
Here is a step-by-step guide to help you out!!
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps,
Marci
Jun 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum won't switch on;got it apart;cord ok;need wiring diagram
Gary
May 24, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G3 won't run
May 29, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
315 people viewed this question
Top Kirby Vacuums Experts
Paul Bade
Marvin
Marvin
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
