Connect your iPod Touch to your computer. Turn your iPod Touch off (hold down the top button and slide the red off slider). Then hold down the top button and the home button for ten seconds then let go of the top button while still holding the home button and KEEP holding it for up to 30 seconds. If it doesn't work the first time, try it again - iTunes should pop up and say that it sees an iPod Touch in restore mode. Click restore and you'll be able to get it back up...
Connect the iPod to the computer with which it normally syncs and sync the iPod, if it will not sync, erase the iPod and put all of the data back on it afterwards
My Touch wil lnot echo the PassCode when I try to login:All help most welcome? Thanks a Million, SEanS
SOURCE: my ipod touch is disabled and i cant hook it up to
you will need to put your touch into recovery mode aka DFU mode.
Here are the steps:
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Iphone
and itouch dfu mode
Plug the
usb cable into the Ipod and NOT into the computer.
Hold the
Home Button down for 5 second (do not release it)
Then
Press and hold the Power Button for approx 10 secs (count them out)
Your iPod
will reboot.
Release
the power button and continue holding the Home button for an additional 27secs.
You may
see the screen go blank or not.
Plug the
USB end into the computer with itunes open.
Your ipod
will mount in recovery mode.
Restore
it and Your all set.
SOURCE: i forgot my password for my ipod touch
i forget my pswor for my ipod touch and now my ipod say ipod is disabled connect to itunes
SOURCE: iPod touch Digital Media Player: ipod touch is disabled...
connect your ipod touch to itunes and then click your ipod and then click update and then your ipod should be good as new
SOURCE: iPod touch Digital Media Player: trying enable disabled ipod touch...
connect your ipod to itunes and then click on your ipod and then click on update. and then your ipod should be good ad new.
Here is how you can do it. Make sure your ipod is connected to your itunes.
1. Turn power of.
2. hold the home button and the sleep/wake button for ten seconds.
3. let go of the wake button. ( keep holding on the the home button for another ten seconds)
4.?»¿ itunes will tell you that there is an ipod on recovery mode. and on the side a button should say restore.
