Question about Rockstar Games Video Game Consoles & Games
The red wire keeps coming unglued on the bottom inside of the drum, what adhesive works best to keep the wire attached?
Posted by jmmmr_z59 on
RockemSockem
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Also two-part epoxy works.
Posted on Apr 13, 2015
Andrew
    Sergeant:
  • 181 Answers
Spray adhesive, you can find it at your local hardware store.
Posted on May 04, 2011
Dewalt dw082 flashing laser
Inside the laser is a small piece of silver paper(self adhesive) this is what the 'out of level' encoder uses to tell the laser when it is level. Is would have come off. You will need to open the laser and re-attach it to the bottom of the pendulum. There is an obvious place for it
Sep 21, 2016 | Dewalt DW082 Laser Plumb Bob
What kind of glue for loose film on 1999 southwind storm 32v cupboard drawers?
The best stuff is expensive, designed for formica application, and usual comes in gallon or larger... but 3m hi strength 90 spray, contact cement or super 77 spray would work. First being best. Recommend 3m 90. http://m.homedepot.com/p/3M-17-6-oz-Hi-Strength-90-Spray-Adhesive-90-24/100151277
Jan 04, 2015 | Cars & Trucks
My fitflop dress style, the leather strip or covering around the supporting platform is separating or unglued, you can see it from the inside, how can I fix it before it comes apart? I only have the
Go to Walmart and buy some "Shoe Goo"....you will be able to reglue your shoe. I usually put my shoe under the leg of a chair or the table leg, so the pressure holds it into place. Let dry for 24 hours....
Jun 11, 2014 | FITFLOP Clothing Accessories
Red drum light on copier not working
Are you talking about the light inside near the drum (the laser) or the maintenance light?
Jan 13, 2013 | Sharp AL 1631 Copier
How to put window on passenger side back on track
take the door panel off... put the window in down position... now you should be able to work the window up with your hands and you will be able to see inside the door where the tracks are and where the window needs to go... just line it up in the tracks and let it come down into place... you will need some good adhesive or silicon in the bottom track which holds the window in place and keeps it from being able to get out of the tracks ...put the adhesive in the bottom track before you push the window all the way down into the bottom track... roll up the window all the way but do not roll it down again until the adhesive has had time to dry fully... replace door panel
Mar 25, 2011 | 1995 Oldsmobile Cutlass Ciera
The window is unglued on the bottom and sides.
The dealer can fix virtually any problem with a late model car. But, if you use epoxy or trim adhesive, you may be able to do the repair yourself.
I once used 'gel' super glue to exactly meter and put glue where it belongs and get an instant bond on rubber to glass or rubber to metal bonding.
Jul 11, 2010 | 2005 Volkswagen New Beetle Convertible
1995 Saab 190 convertible, the rear windshield is detached at the top and bottom. It there a way to re attach this properly. The strip the window is supposed to be attached to is torn on the outside but is...
I'm not sure if it is exactly the same problem or not. In my case the glass detached/unglued, on both sides, from the strip that is sewn to the top. I used Clear RTV Silicone Adhesive and Sealant made by ProSeal and purchased at Harbor Freight.
Be careful not use acrylics . Even though they will water proof, they become brittle with temperature changes. You want and adhesive that remains flexible.
Good luck.
Nov 09, 2009 | 1995 Saab 900
The rear glass has come unglued and the convertible top does not want to stay attached is there any way to fix this without having to replace the entire top?
Try gluing it back together with 3M super weatherstrip and gasket adhesive, (you can get this at Auto Zone). This stuff bonds like crazy!!!! Follow the directions on the box.
Oct 03, 2009 | 2003 Volkswagen New Beetle Convertible
1998 blazer rear window latch comes unglued from window
You need mirror glue. If this is help, please post as such. If it is a fixya, please post as such.TY
Jan 21, 2009 | 2001 Chevrolet Blazer
Maytag atlantis
UNPLUG DRYER, 220v is not fun
You get in the back of the dryer, from the front.
maytag dryers have two screws in the curve of the bottom of the front panel. (Note:screws may be torx-secure screws, cut a slot in them and use a flat screwdriver or pick up a torx-secure #20 bit at a tool shop, star shape with a pin in it)
remove the screws and the front panel can be swung up from the bottom and unhooked.
unplug door switch wires
reach under drum, for belt tensioner, pull belt off tensioner. and motor pulley
lift drum up and slide out forward
under drum are 2 rubber tired rollers, check for free motion, replace both if either is seized
the drum has felt bushes on it
examine felts for wear, replace if worn.
ensure all felt and adhesive is scraped from drum before fitting new felts, if there is any left, it bumps/thumps and knocks every rotation (best adhesive is Hi temperature red silicone)
use 2-4 pairs locking pliers(visegrips) to install felt
  • put adhesive on drum edge
  • clip felt in place at one point with visegrip
  • pull felt around drum, clipping in place as you go
  • let sit in clamps till adhsive sets
reassemble drum in reverse order
38d7d07.jpg while you got it apart is a good time to clear any lint from exhaust vents and squirrel cage fan,
felts last cost $30/pair rollers $9/pair
takes 45 minutes now to change felts, I do rollers while the adhesive sets, had a lot of practice, replace the belt, cost is minimal, it has been *****ed pulling the drum against the worn felts or rollers, and will break soon, dont want to open up again
Aug 29, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Video Game Consoles & Games Logo
762 people viewed this question
Top Rockstar Games Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Harrie
Are you a Rockstar Games Video Game Console and Game Expert? Answer questions, earn points and help others
