Hi Linda,
1.Open the front cover.
2.Pull out the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tab toward you to open the rear chute cover.
5.Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull out the paper with the other hand.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back into the machine.
8.Close the front cover.
If the error is not cleared, turn the power off on your Brother machine.
If the problem still continues, please contact Brother Customer Service from "Contact Us".
9. Make a test copy. If the machine jams again, try the followings:
10. Make a test copy. If the machine jams again, use new paper from a fresh, unopened ream of paper. If the machine still jams, please contact Brother Customer Service from "Contact Us".
Still having Problem Then follow Us For
Brother Printer Support
