Question about RCA Televison & Video
Do not know how to program the systemlink3 universal t,v. remote control to my t.v.
Posted by jevermendoza on
Shaun Carlson
    New Friend:
Option 1:
To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE***Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Option 2:
Thanks for the hints on your web site. For the RCA SystemLink 3 with the key pad, I could not get the sequences described to work. But they did point me in a direction which worked for my remote:
  • With the TV on (for TV)
  • Press and hold code search until the light stays on
  • Press TV (for TV) button once
  • Press the on/off button once
  • Thereafter, the light will stay lit and every couple to three seconds it will blink twice indicating it is trying another code.
  • When the TV turned off, I pressed enter. Thereafter the unit worked.
Posted on May 04, 2011
Need code for rca systemlink3 for magnavox dvd?
Check these codes: 007,008,019,021,026,028,029,032,033,040,041
Nov 26, 2012 | RCA Universal Remote Control
I can't find a code for a Systemlink3 universal remote for a Durabrand TV.
Hello
RCA systemlink-3 universal remote control has no setup codes with Duraband TV. Sorry.
Oct 13, 2011 | RCA Televison & Video
WHATS THE CODE FOR RCA TV ..I HAVE A ONE FOR ALL UNIVERSAL REMOTE NEED THE CODES TO PROGRAM MY RCA TV
You received a list of ALL Codes with your universal.
I got this off the internet. But I do not know what type of universal you bought. You didn't mention it.
Good Luck.
Here is the link if you need it. :0)
http://www.google.com/search?q=universal+code+for+rca+tv&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
rca
Nov 07, 2009 | Universal Remote Control P000203220-1...
Have rca remote systemlink3 need codes for magnavox tv
http://www.universal-remote.net/philipsmagnavox.html
Sep 09, 2009 | RCA Universal Remote Control
Universal remote
The bad thing is that not all universal remotes work for all functions of a tv. The thing is the factory remote. Order one at ROMOTES.COM. They sell them at a good price.
Oct 26, 2008 | Sharp 27K-S100 TV
Systemlink3
  1. Make sure the device you are programming is turned off.
  2. Press and hold CODE SEARCH.
  3. Press and release TV, VCR, or CABLE corresponding to the device to be controlled. The indicator light will flash once to indicate the search is enabled.
  4. Release CODESEARCH.
  5. Press OFF/ON repeatedly until the device turns on.
  6. Press CHANNEL V (channel down) for verification. DO NOT press any other buttons at this time.
If the channel changes on the device, the code is valid. Press ENTER to complete the search.
If the channel does not change, turn off the device (without attempting to use the remote). Then continue search by repeating steps 5-6. When all codes have been searched, the indicator light will flash twice and the remote will return to the normal mode.
May 03, 2008 | RCA Universal Remote 3 Device Remote...
Rca systemlink3 remote control
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
DABII
Nov 30, 2007 | RCA RC-U703SP Remote Control
SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
MY TV IS SANKEY AND I CAN`T FOUND THE CODE IN THE LIST OF MY SYSTEMLINK3 RCA, Please i need help! Thank`s
Nov 06, 2007 | RCA RCU300WBL Remote Control
Televison & Video Logo
158 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
