Question about Panasonic Viera TH-42PZ80U Plasma TV
Received a panasonic th-42pz80u from my father in law. He said it did not work. I plugged it up and it worked for a few hours. Now I get nothing when I plug it up. Is there anything I can do to restore power for good?
Posted by dankdeville on
David Bukovaz
    New Friend:
  • 144 Answers
Try using a different outlet, if that doesn't work see if you have another power cable that is the same power as the one on the T.V. and try that. If that doesn't work then there is probably a problem on the board near where the power plugs in. It could be fixed by a firmware update or it may need to actually be repaired.
Posted on May 04, 2011
How do i fix an 08 panasonic plasma tv,it will work perfect for a few hours but then goes back to green highlights,i have pics. I
It sounds like it's overheating. If you can put a small electric fan behind it and see if that fixes the problem.
My plasma has a regular box fan behind it to cool it off.
Nov 10, 2014 | Televison & Video
Panasonic plasma TH42PV8H blinks 12 times
This is an error code indicating failure of some board and might need attention by a qualified service technician. Switch off TV manually, switch off power, remove plug and retry after 48 hours.
Jul 30, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I plug in my TH-42PZ80U and it doesnt turn on but a red light blinks ten times.
Apparently this common problem is due to a faulty power board. Contact Panasonic for a replacement if it's under warranty (hopefully) or a local repair shop. Good luck!
Jun 06, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
The tv shut off and never came back on.
Tries unplug,replug the tv it back like an hour later.The tv now,it resetting itself back to the factory setting.The tv should work now.If it does not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 16, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Screen has a long black line down the center.
I also have the TH42PZ80U and I just had the certified Panasonic repair person out. The problem is this is the THIRD time in two years. Any quesses on what's wrong? It's a bad panel, again. That's right, three bad panels in the two years I've own this tv. I am now one month out of the panel warranty and guess how much the bid is to replace the panel. $1542! I only paid $1300 for it. Panasonic better make this right. I think a whole new tv is in order just for my trouble. After reading about so many of us having this problem, we are probably getting close to a class action law suit.
Apr 29, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Replace screen
This is a plasma panel and the part number is: MD65F10A1J and the cost is $3387.95 with a refund of $200 when the bad panel is sent back.
Dan
Mar 22, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma tv
complete guide here...http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/model.TH-42PZ80U
Mar 03, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Viera TH-42PZ80U Plasma TV Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
