Question about Leapster 2 Handheld Game
My daughter's Leapster 2 Handheld game's screen is dark. She cannot see any of her games that she tries to play. I tried using the brightening button, but it doesn't help. Also, have replaced the batteries multiple times and that doesn't help either.
Posted by wjburma on
seivadwuh
    New Friend:
  • 23 Answers
Are the batteries you are using the correct size/voltage for the leapster? I believe it takes 4 AA/LR6 size batteries at 1.5V each.
has the product been dropped or bashed?
Posted on May 04, 2011
Leapster restarts select cartridge game
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
Aug 13, 2014 | LeapFrog Leapster 2 Learning System
I turn on my daughter's Leapster 2. I sign in. I click "Cartridge Game". The screen goes black & then It goes back to the "Leapster 2" screen, followed by the "if you...
You have to make sure that your Cartridges is clean. Try to vacum of blow both of the cartridge hole and also the place where you put the cartridge, Sometime very small tiny dirt will makes that the cartridge cannot be recognise by the console.
Instead of 1 starter game and a few demo game that you get from Leapfrog Connect, you can also get more downloadable games for your Leapster 2. You can get it here:
leapster-2.blogspot.com
Jun 08, 2011 | LeapFrog Leapster 2 Learning System
Leapster2 is 2 1/2 years old. Placed brand new batteries in Leapster2. Try to power it on, screen comes up like it is going to turn on, and it turns off.
Welcome to FixYa!
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Do comment if it helped or not in any manner ill know.
Apr 15, 2011 | Leapster 2 Handheld Game
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
The touch screen ain't working
Try to calibarte it:
Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
Source:
http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1736&p_created=1221582020&p_sid=DqRj3Kxk&p_accessibility=0&p_redirect=&p_lva=1725&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MjkxMyZwX2NhdHM9JnBfcHY9MS4yOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9Y2FsaWJyYXRl&p_li=&p_topview=1
Dec 26, 2010 | Leapster 2 Handheld Game
My daughter has a Leapster 2 (pink) hand held game. We can not get it to sign into her name, so she can not play games. Can you help?
Remove the game cartridge, while holding down the button with the "?" turn the unit on. Then the screen should tell you to press the "A" to calibrate the stylus. Finish the calibration by touching the crosshair when it appears. After I did this everything was fine. Good luck ....thaks to Nicksdad who posted this response to a previous post. Worked for me...try it.
May 16, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 will shut off right after the "important" screen
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
I hope this helps.
Good Luck.
-The Johnson Family :-)
Apr 06, 2009 | LeapFrog Leapster 2 Learning System
Leapster screen not working
Apparantly, the Leapster screen issue is a common problem. While this suggestion is not ethical and since my game was near perfect condition, I went to Wal-Mart and bought a new one of the same color and then returned the broken one.
Jun 12, 2008 | LeapFrog Leapster Educational Game: Disney...
Leapster screen
Sounds like it needs to calibrated - see http://gobaco.wordpress.com/2006/10/31/how-to-calibrate-the-leapster-handheld/
for info,
Feb 19, 2008 | Video Game Consoles & Games
Leapster 2 Handheld Game Logo
431 people viewed this question
Top Leapster Toys Experts
James Hensley
James Hensley
JessicaChane2345
Don A
Don A
Are you a Leapster Toy Expert? Answer questions, earn points and help others
