SOURCE: Pioneer SuperTuner III D wiring installation diagram which is wire is the ground
Unless someone cut it off there is a black wire with a spade terminal to connect to the car chassis. Now go to http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070339_338834008,00.html Register, and download your manuals. Problem solved.
SOURCE: owner's manual needed for a Pioneer EEQ MOSFET 50WX4 Super Tuner III D
Turn the tuner off, With the clock display on Push and hold down the white button on the top right side, (right top corner) the Hour LED will start to flash, use the four arrow adjustment button on the right side to adjust
SOURCE: manual for pioneer deh-10 super tuner
Have you tried www.PioneerElectronics.com? They have the Manuals if you go to Customer service on the Site and Do some Searching. That's where I get ALL of mine and I only Buy Pioneer!
SOURCE: KEH-P5750 speaker wires
Can not find you a free manual but you can buy one for $10 here.
http://www.user-manuals.com/advanced_search_result.php?keywords=Pioneer+KEH-P5750+manual&forward=plist
Good Luck and Please Rate FixYa!
SOURCE: how to connect a pioneer super tuner to a 91 honda accord
With a DC voltage tester, check the two power leads for 12+ volts and proper operation, and be sure the unit is properly grounded.
The two power leads are,
1.Constant feed: which should be connected to an un-switched power source that delivers continuous
power to the units memory.
2.Switched feed: which should be connected to a switched power source controlled by the vehicles ignition switch.
Before installing in dash check unit for proper operation.
Good luck
Aduz
