Question about Lexmark X2690 All-In-One InkJet Printer
I have seldom used the x2690 that came as a package with my computer (warranty expired) I used it one week and tried the next and it will not turn on? It's getting power through out the machine but it will not turn on?
Posted by haresun on
Lexmark
  • Official Brand Answer
  • 3,344 Answers
Please go through the following checklist
- Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
- Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
- Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue. - If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
- Make sure the correct power supply is connected to the printer.
However, if problem continues, please contact Lexmark technical support for additional assistance.
Source: The Printer is Not Powering On
Posted on May 10, 2011
Non-working print cartridge. The cartridge was new (expiration date Aug. 2014), installed less than a month ago, but ceased working after very little use. The computer is used mainly for text so that a...
If the printer cartridge had an expiration date of 2014 it has probably dried up in three years. Although it has not been opened it will still be dried out after a few years.
Sep 25, 2017 | Office Equipment & Supplies
The computer fan can be heard when the computer is started but the screen does not light up. What do I try next? The computer is the one piece macbook with a 13 inch screen one and one-half years old.
> what do I try next?
Take it to an authorized Apple repair depot, for service, whether the warranty is still valid, or even if the warranty has expired.
Feb 26, 2011 | Apple PowerBook G4 Mac Notebook
My vizio 32" tv won't turn on, only the red led light does. My warranty expired one week before the tv stopped working. can you please help me
I would try real hard to get it repair under warranty, they may bend the rule sinc it is only one week over warranty. Right now the 5vdc standby power supply is working. Typical repair for LCD TV is $200 and up plus parts. If they refuse, I would not buy another VIZIO.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 21, 2010 | Vizio VW32L 32 in. LCD HDTV
Toshiba A205-S5879 laptop won't boot
Please resort to your installation discs that came originally with your computer package. Those install discs can be used as recovery discs. Try to do an OS repair install from those discs. If the problem still persists, I would suggest to wipe and format the hard disk and start a clean installation again. I understand your warranty expired but if it was only let's say three days ago, it should still be disputed. If your new installation doesn't work either, then I would suggest you contact your supplier to work out a replacement of your hard disk. Good luck.
Feb 05, 2010 | Toshiba Satellite A205-S5879 Laptop
Acer aspire 2930 series when using bluetooth flashes and laptop starts writing itself
it's a hw problem. when i using my easyport iv it doesn't occures. only when the display is turned up. after 2-3 hours of use i think it's overheating. (i tried to buy a waranty extension after i bougth the laptop, but acer said "it isn't available". i think thew know someting about this problem...) i bought it in Jan 2009, and the problem occured in Jan 2010. just after the warranty expired. wierd...
Mar 01, 2009 | Acer Aspire 5100 Notebook
Ink level reset button for Lexmark X2690
There really isn't. Lexmark's 'official answer' that I have seen is this:
Genuine Lexmark inks and cartridges are perfectly matched to the printing system to ensure that every document produced is of the highest possible print quality, providing long-term dependable service from your Lexmark printer. Using incompatible inks in an attempt to extend the life of a genuine Lexmark cartridge beyond its recommended usage can cause failures in several different areas of the printer. Any such damage to your printer caused by refilled ink cartridges will not be covered by your Lexmark printer Warranty, Extended Warranty or Service Agreement.
If the error message stopped you from using the refilled cartridges, you shouldn't have damaged the unit in any way.
Steve
Feb 18, 2009 | Lexmark X2690 All-In-One InkJet Printer
Sudden power failure
my swisstec tv had exactly the same problem this week march 30th and the 12 month warranty expired.....i went to skymediauk online and extended my warranty ..free for 3 months they collected it,fixed it and returned it in 46 hours
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
LEXMARK PRINTER/SCANNER ISSUES
also try unplugging the USB cable , wait a little while then plug it back in and see if the computer detects it
Oct 06, 2008 | Acer Aspire 5100 Notebook
SYNTAX OLEVIA MODEL# LT37HVS LCD
My LT37HVS was purchased in 2006 and the LCD light engine "blew" with a loud noise and only displays super dim picture-in-picture component feeds.
Need service for a quote. HELP!
Nov 17, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Soyo 32" LCD flat panel
Better to send it back before the warranty expires, the set has issues
Oct 21, 2006 | Soyo DYLT032D 32 in. LCD Television
Open Questions:
See all Lexmark X2690 All-In-One InkJet Printer Questions
Lexmark X2690 All-In-One InkJet Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
