Question about Alpine CDE103BT CD Reciever iPod and USB Controller with Bluetooth Car CD USB MP3 Player
How do I set the phone? I just took it one of my van and put it in my car and now I can't get the phone working
Posted by horne5649 on
Jose Cruz
    New Friend:
  • 35 Answers
Go to the following LINK and on page 18 you will find the instructions on Setting up Bluetooth.
Posted on May 04, 2011
Why my 2000 pontiac montana won't shift gears at all?
recheck the transmission connections either loose or not properly installed
Aug 21, 2017 | 2000 Pontiac Montana
How to change afuel pump on a 1993 Aerostar ford van
put the van up on ramps in the rear, unbolt gas tanks straps, hopefully u take gas out before, take clamps off filler neck and pull big and small hose off let tank down slow and disconnect wiring plug and fuel lines to pump then pull tank out from under van. very carefully unscrew big washer that holds pump in, put in new pump and reassemble the way you took it out, good luck, remember be gentle with fuel lines and wiring
Jan 05, 2011 | 1993 Ford Aerostar Extended
..Ihave a 2004 venture van.
sounds like water in somewhere ?? but where without my head under bonnet i couldnt say ,but its soaked something so perhaps it will be ok when it dries out
Sep 17, 2010 | 2004 Chevrolet Venture Passanger
Van took a few tries to start. Then once off nothing worked.
Might be time for a tune up?
Does your car have a anti-theft system that uses a resistor in the key? I have had several instances when I tried to start the my '95 GM auto, runs perfect normally, but nothing. I traced it back to the key. Probably not always put in correctly.
Thanks for your question at FixYa.com
Jan 18, 2010 | 1996 Chevrolet Astro
My Plymouth Voyager (1999) stop on me, and When I
Sounds like one or more of your fuel injectors is stuck open and dumping raw gas into the exhaust system. I would replace all the injectors since there was sugar run through it.
Jun 10, 2009 | 2000 Daewoo Lanos
Van Wont Start Then Start's
please explain what you are calling a crank cap?? is it the magnetic pick up sensor on the flywheel if so either clean the connections in the multiplug or try putting the old one back on
Apr 05, 2009 | 2001 Chrysler Voyager
1994 T & C alarm (factory) goes off stops me from starting my Van
you can try a couple of things put the key in the drivers door lock manually lock and unlock the door
with it unlocked try starting the car if that doesn't work disconect the battery turn the key on then hook up the battery and try to start it also check your owners manual about the alarm
good luck!!
Jan 29, 2009 | 1994 Chrysler Town & Country
Used Van
go to parts store buy new ignition cylinder ford are easy to replace. Once you have new ignition turn on old ignition to run position just under the switch you will see a hole push in the silver pin on that hole and pull out old switch and insatll new hope that will solve your problem
Sep 07, 2008 | 1984 Ford Mustang
Vtech 8L55 2 unit portable phone
I just had the same problem. Could be dirty terminals. I took the battery out, cleaned the terminals on the battery and phone with a pencil eraser, put the battery back in and it's working fine. (Says fully charged, where just a few minutes ago it said low battery).
Nov 06, 2007 | Vtech IP8100-2 Twin Cordless Phone
Alpine CDE103BT CD Reciever iPod and USB Controller with Bluetooth Car CD  USB MP3 Player Logo
96 people viewed this question
Top Alpine Car Audio & Video Experts
Robert Salgado
Robert Salgado
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
