Question about JVC KD-NX5000 Car Video Player
Sat radio not showing up when scroll thru av options and bluetooth intermittant.
Posted by wgfinney on
eb0337
    New Friend:
  • 20 Answers
Do you have a satellite radio tuner? if not, you will not receive satellite radio.
Posted on May 06, 2011
Alpine CDE 9845 ---> Pioneer DEH-P3900MP
Hi
It is no problem for replace your alpine stereo and you can get read review Pioneer AVIC-Z140BH . It has Touchscreen In-Dash, Navigation AV Receiver, iPod,Sat radio,Bluetooth
Read more review or check from Amazon.com
Nov 01, 2013 | Pioneer Car Audio & Video
Are the 7 different programs for 7 different days or are they exclusive?
There are 7 ON events and 7 OFF events
http://waterheatertimer.org/pdf/Woods-59028-59018.pdf
When programming the timer, you select individual days or blocks of days.
For example program1 ON time
Set the Hour
Set the minutes
Press the day key to scroll through the possible choices.
Then you set program1 OFF time
Set the hour
Set the minute
And then press the day key to scroll through the possible choices.
The choices are:
Each individual day
Monday thru Friday
Sat-Sun
Monday thru Sat
Monday thru Sun
Monday-WED-FRI
Tues-Thurs-Sat
Mon-Wed
Thurs-Sat
The key is to set the ON and OFF times for the same days or blocks of days
For example program1 ON is 8:00 am Mon thru Friday
Set program1 OFF for 3:00 pm Mon thru Friday
and then program2 ON is 8:30am Sat-Sun
program2 OFF is 5:00pm Sat-Sun
Program 3 ON is 6:00pm Tues-Thurs-Sat
Program3 OFF is 9:00pm Tues-Thurs-Sat
Program4 ON is 6:00pm Sat
Program4 OFF is 11:00pm Sat
Programs5, 6 and 7 might not be needed
The key is to make a chart of times before setting timer.
The chart will prevent conflicts in programming where the timer does not operate as expected.
Nov 08, 2010 | Coleman Cable Woods 59018 InWall 7Day...
The acer travelmate 2310 has a bluetooth sign on the front of it but i can't see anything about bluetooth in any of the menus. do you know if it does have bluetooth?
It is a manufacturing option as to whether your individual laptop actaully has the bluetooth transmitter in it. If it is not showing up in the device manager even though the driver is installed, then I would venture to sat that you do not have the bluetooth on your particular model.
Oct 03, 2009 | Acer TravelMate 2300 Notebook
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
OR
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
Aug 12, 2009 | Televison & Video
No Sirius function available.
I have the same problem. When scrolling through the source options, the display goes from tuner-cd-aux and back to tuner...no sat. radio. need help.
May 29, 2009 | Clarion XMD3
How to hook up the sirius stratus 5 radio in my 2008 rav4?
I have sirius installed in my 2008 RAV4 JBL system.
There is an adapter made by VAIS technologies http://www.vaistech.com/ that is called a soundlink. It comes with instructions for the connection. The Sirius radio is hidden in this installation, and is controlled by your JBL system. The antenna runs up the side of the windshield (hidden behind the plastic moulding) and mounts to the top right corner of the roof.
HOWEVER- you will not have the full funcionality of the Stratus 5 radio- which has more funtionality that the JBL system can control. Also, the Scrolling feature on the Stratus 5 screen does not work on the JBL display. . . you get the first 15 or so characters, with no scrolling.
I love having an integrated satelite radio in my car, but I do miss the better screen, and the pause feature I had on my sportster (in my old car). Good Luck.
Dec 25, 2008 | 2008 Toyota RAV4
JVC KD-NX5000 NOT WORKING PROPERLY
I had the same problem, where the Sat radio, the bluetooth and the ipod were all non-functional. Turns out, they all go through one central hook-up, so you have to make sure that connection is good.
When mine did not show up or function, I looked at the install under the foot board of the front passenger seat that the installer did, and nothing looked out of whack. Upon closer inspection, one of the cables was had been pressed out of it's proper place and loosened enough to cause a bad connection.
I don't care for the install, but there was no problem with the equipment, so check all of your connections. Even to the point of pulling them out and reconnecting them to see if that fixes the problem.
Robert
Jul 08, 2008 | JVC KD-NX5000 Car Video Player
Alarm set for certain days
Depress Alarm1 and hold while you then press the alarm mode button until it shows Mon throught Fri. You will then have both Alamrs set for the weekdays but you can set them to different times.
Nov 23, 2007 | Emerson Smartset Clock Radio
JVC KD-NX5000 Car Video Player Logo
64 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
