You
might have to uninstall the mouse and its drivers then restart your computer
then reinstall the mouse and its drivers
click
start right click on my computer select properties device manager control
scroll to mice and pointing devices you might see a yellow question mark? right
update driver
click
start control panel mouse you should see 4 tabs buttons,pointers,pointer
options and hardware under hardware you have options to troubleshoot also you
can select properties under driver you will have the options update
driver,rollback driver or uninstall in xp
click
update driver in
make sure the battery is good
((has full charge))also you might test the usb device for the mouse is inserted
correctly into the usb port (if applicable)
Windows
7
hope this helps
PLS REPLY OR COMMENT. THANKS
