To print a single page from multiple page just
open the page which you want to print and press Ctrl-P keys or select print
option from file tab on the above of the page. Then there will appear a print
window to select options as u require and then print. In this window just
select the "Current page" and click print
The option to print a single page will be in the print options when you go to File, Print. The option will be called Print, Page Range. You can specify the page number you wish to print from there.
Move the cursor to the page you want to print. Then click File - Print then in Page range select Print Current page - then click OK to print.
SOURCE: I have a Canon Pixma iP1700 printer. When I try
This is a common issue with all printers and faxed. Try to clean the rollers and use different paper weight
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
Testimonial: "Thank you."
