Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
How do iset date and time stamp on canon ixus 40
Posted by mmichaelgran on
Anonymous
    Scholar:
  • 51 Answers
here you can find the manual for your product:
http://files.canon-europe.com/files/soft24168/Manual/IXUS30IXUS40_CUG_EN.pdf
if you go to page 76 of the manual, you'll find detailed instructions how to setup date stampo embedded in picture.
Let me know if this helped you, bye
Posted on May 04, 2011
Hi im using a canon digital ixus 9515 camera and I have the wrong date stamp on all my recent photos. How can I delete the date?
There is no way you can delete the date stamp from the photos you have taken.
For future photos you can either correct the date or disable insertion of date stamp.
Sep 04, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
Hi, how do i remove the date thats stamped on all my pictures. I have a canon ixus 105
Press MENU button.
Use Function Button arrows to bring up the camera icon at top of screen.
Use Function Button up or down arrows to get to Date Stamp heading on screen.
Press right arrow to get Date or Date and Time.
Select OFF
Press Menu
Done
Jun 28, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Hi all, pls hep me to set up the date stamp on my canon ixus 75. i used to have it on my camera. Thank you
The date stamp only works in Postcard mode. Press Func/set, scroll down to the bottom, then across to the mountain with clock icon. "Postcard" will appear in the selection. Press Func/set.
Now press Menu, scroll down to Date Stamp and across to set date or date and time, then press menu again.
Dec 04, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Ixus 75: "Date stamp" does not work. I want to have time & date on the photos, but I can not do it. How can I fix this?
Image size (L, M1, M2, M3, S, Postcard) must be set to Postcard. Then make sure that on the Record menu Date Stamp is set to Date or Date/Time.
Mar 13, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Date stamp
To set date stamp follow the instruction:-
1) Press MENU button. 2) Select REC Menu. 3) Use the up and down buttons to Select Date Stamp. 4) Toggle to the desired opetion OFF or ON.
Note:- Ensure the date & time is set before using date stamp function.
Good Luck
Mar 06, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
dsc_include_date01_tcm13-520510.jpgTo set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm13-520511.jpgBe aware that if you take pictures with this option enabled, the Date and Time cannot be removed from the pictures at a further time. It will permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
Feb 28, 2010 | Canon IXUS 860 IS Digital Camera
Hi how can i turn on date stamp on my canon ixus
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Nov 23, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Date display in photos in IXUS40
here is the solution:
your date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
[email protected]
May 09, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Push the function/set button. Press the directional button down to select Date and Time.
Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Date to appear on photo
Set the image size to 'postcard'. Press the Function key, scroll down to the bottom icon and select postcard (L, M1, M2, S, postcard). Press Function key again.
To turn the date imprint on, go to the Record menu and set the option for Date Stamp to Date or Date & Time.
Jan 06, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
