Question about Ariston Technologies AW129NA 16 Lbs Front Load Washer
The On-Off door lock LED flashes rapidly at the same time with Delay, Timer and Rapid LED. and it wont start.
Posted by uros_neskovi on
Anonymous
Many times faults like this can be cured by Uplugging the washer from the mains power supply and leaving for 10mins. Also check all filters, drain and supply lines are clear and not kinked.
Posted on May 04, 2011
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Aug 12, 2007 | Indesit W 123 Front Load Washer
My Hotpoint BWM129 drains at end of a cycle but doesn't proceed to spin, fault lights flashing are rapid Door locked and intermittent Delay Start. Does this fault code indicate a faulty drain pump or
Engine fault or main board fault. Most likely main board.
Check cable harness from main board to engine. Check the carbon brushes on the engine. If its all okay, replace main board
May 21, 2014 | Hotpoint Washing Machines
Ariston1400wd will not switch on. LED lights on door lock, timer delay,and rapid are all flashing
Hi Alistair
The Ariston 1400wd unfortunately doesn't have a very good reputation. From what you've described it sounds like the main control board has a fault on it, but this will need to be verified by a competent technician because it is also possible (though a little less likely) that one of the sensors is sending back the wrong information to the board. I'm sorry, but really the best thing to do would be to get a technician to verify exactly what's going on with your Ariston, this can't practically be done by email.I wish you good luck with it and I'm sorry I couldn't be of more help to you.J Knol
Nov 01, 2011 | Washing Machines
Brinks timer Model 46-1022 has an intermittent flicker with CLF and LED bulbs. (I have not tried recently with incandescent bulbs)
46-1022 is rated incandescent and rapid-start fluorescent ballast.
CLF has electronic ballast and not rapid start.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
For single-pole and 3-way timer that works with CFL and halogen, use Aube
http://waterheatertimer.org/Aube-timers.html
Aug 15, 2011 | Garden
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Door locks dont operate with remote key fob
Touch Key metal to lock cylinder metal then unlock
Jul 29, 2008 | 2001 BMW 325
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Ariston Technologies AW129NA 16 Lbs Front Load Washer Logo
786 people viewed this question
Top Ariston Technologies Washing Machines Experts
Marvin
Marvin
Harrie
ray gallant
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
