Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
POWER FAILURE AFTER FEW MINUTES - VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
Posted by guddivin on
G33k
    Guru:
  • 485 Answers
If your power is failing at a few minutes, you could have a bad power supply, power cord, or maybe a bad motherboard.
If you have a spare power supply, try using that and see if the problem resolves itself. Also try a new power cord.
Check that you have configured the connections properly.
If this does not resolve the issue, you may want to return the motherboard for a replacement through ECS or the company you purchased it from.
Thumbs up my solution if it is helpful!
Posted on May 04, 2011
I cleaned the stove it's quite old and pf came on and now it doesnt work at all
Pf is power failure. Cut power to unit for a few minutes. Then restore power and reset clock. If that doesn't help, it's probably a control issue.
Sep 29, 2017 | Kitchen Ranges
Total shutdown after after a few minutes
This is a power supply failure.
infocus.dex.com
5E.13440.003 PCBA, POWER BD$78.90
Oct 31, 2013 | InFocus IN102 DLP Projector
After two or three minutes of travel, the power
You got some bad batteries or your charger is not working. If Medicare purchased the chair contact Repair Xpress at 1-877-581-3733 Medicare will pay for most of the repairs
Jul 25, 2010 | Quickie Wheelchairs Quickie Aspire...
Replaced cartridge (black) but low-ink light on printer still flashing and printer won't print
Have you reset the printer? If not, follow the instructions;
Remove the cartridges, disconnect the usb, switch off, unplug the power chord, leave it off for few minutes. Again switch it On without the cartridges installed and without usb cable connected to it, press the power button several times while it boots up, and leave it on for few minutes, again shut it down using the power button and install the cartridges, connect the usb cable and restart your printer. This will fix your problem if there isn't internal/system failure/faulty.
Good luck.
Thanks for using FixYa.
Jun 22, 2010 | HP DeskJet 6840 InkJet Printer
My c309a HP photosmart premium says (ink system failure) 0xc19a0036 i have already done every that unit has asked me to do and even the on line help line. But still it's not printing. help
Have you reset the Machine? If not, follow the instructions;
Good luck.
Jun 22, 2010 | HP Photosmart Premium C309A All-In-One...
The dryer runs for a couple seconds and then give a PF code which I think means power Failure. brand Frigidaire
that is a power failure code. check the main cisuit breaker and the cord to the dryer and make sure the connections are tight.unplug the unit for a few minutes and plug it back in this should clear the pf code out.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Screen says power failure occured during cycle press start/pause to resume cycle..nothing happens
sometimes if these machines are running during power failure they get lost in thee own programmin g
this particular machine is notorious for it
unplug the amchine and let it sit for a few minutes
plug it back in and you should be good t5o go
Oct 26, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Television turns itself off after a few minutes, then turns itself back on after a few more minutes
Hi there! My guess would be dry joints (loose solder connections). First check the power supply,line stage or around the vertical or processor areas. Depending on the age of the set it may very well be due to general component failure. The latter may be a bit difficult to find. However start by replacing the electrolytic caps in the power supply. If all fails refer to repairer. Regards and good luck, JUS004.
Jun 09, 2009 | Sony Televison & Video
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
Top VIA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Atiq
ChinthakaJ
ChinthakaJ
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
