Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo Drive Logo
Question about Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo Drive
The Computer doesnt detect the DVD ROM - Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo Drive
Posted by cooldudeprat on
Brian Sullivan
  • Samsung Master
  • 27,725 Answers
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Posted on May 04, 2011
Computer doesnt detect drive
Not exactly The computer detects the drive but windows does not detect the driver. Uninstall the drive in the Device Manager and Restart the computer. This will reinstall the driver..
MY dvd writer not detect dvd. but detect cd. this is dvd problem.
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope it helps
I have just installed a fresh copy of windows 7 on my aspire 5738G and after the instalation was complete the PC doesnt detect the cd/dvd rom anymore. It doesnt even show in My Computer. I have the latest...
If you have installed the chipset driver, you could locate the producer of the CD/DVD ROM, and check if there is drivers to download from their homepage.
MY DVD ROM IS NOT DETECTED BY THE COMPUTER HL-DT-ST DVD-RAM GSA-H54N
my DVD ROM IS NOT DETECTED BY THE COMPUTER HL-DT-ST DVD-RAM GSA-H54N
1helpful
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
My computer cannot detect cd/dvd
have you checked the cd/rom cables? if reattaching the cables both to the drive and motherboard doesnt work, test the drive in another computer. get a new drive or cable if you have to.
6helpful
4answers
1helpful
Pop up says doesnt detect dvd in rom
Hi:
If your DVD drive doesn't detect a DVD, or a CD disk, And the drive still shows up when you go to the "
my computer " page , it is most likely that the DVD drive is defective, There is not a simple software fix for this, and you need to shop for a new drive. A new DVD burner can be found for approx $40 at most stores.
Display Dvd Rom
Hello my friend, please try to reboot your computer then goto CMOS and check if the DVD Rom that you have is detected by your system. If it does not detect then you can manually detect a device using CMOS function. Also try to check if the connectivity of your DVD Rom is not diabled otherwise enable it to detect your device. If all the above steps you followed then the result is still the same then please find a computer technician in your place then let him open and fix the problem.
If you need more assistance my friend please reply to this post.
Thank you.
1helpful
2answers
MY COMPUTER DOES NOT SEE THE CD-ROM
my cd and dvd not detect of my computer how cd and dvd detect tell me a solution
Top Samsung Computers & Internet Experts
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
