HEWLETT-PACKARD Hewlett Packard HP 250-GB Pluggable SATA 7200 rpm Drive 1 SATA Hard Drive Logo
Question about HEWLETT-PACKARD Hewlett Packard HP 250-GB Pluggable SATA 7200 rpm Drive 1 SATA Hard Drive
My hp250 is in safemode . dont know what to do ? please help me thankz
Posted by myriam_tay on
Brian Sullivan
  • HEWLETT-PACKARD Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
Posted on May 04, 2011
When i tap f8 cant boot into safemode gets stuck in safemode need help please
dont go to safe mode jst start window normally ntng will happen
I have a latitude D620. and i just bought it and had to transfer ownership with dell just to get passed the bio password. now there is a windows log in that needs a password and i dont know the original...
Hi
please try this
press the power up key and keep pressing the F8 key until
the safemode box comes up
then choose safemode with networking
then click the name administrator if its there
or any other name that is a administrator without a password
if and when you are on the desktop and everything is loaded
go to
start
settings/control panel
user accounts
change an account or create an account as an administrator
click on the account name which is causing the problem
click on remove password
now you can either leave the account without a password
or create a new password or delete the other account completely
your choice
please let us know if this has helped you
so that we may be able to help others
many thanks
Ok after my computer boots up and i log in the icons come up and like a minute later it all freezes i cant do anything please help i dont have any computer experience
Try accessing safemode or safemode with networking,
if you're able to access safemode or safemode with networking without having the same problem disable start up items and services of your computer and if your able to access safemode that only means that one of the software in your start up item is causing the problem and if you're not able to access it run the hardware diagnostic of your computer ( if that's a dell you'll need to access it in f12 ) if the test passed without any errors you'll need to reinstall your operating system but if it fails then it give you an error contact tech support of dell give them error they tell you what you need to replace. By the way if your just gonna end up reinstalling your operating system, BACK UP your files first before doing so.
Reformat laptop
There should be restore partition on the hard drive. Right after you turn on the laptop press F11 to start the restore process.
It there is no option for that, press F1 after you turn on the laptop to enter the BIOS. Under Startup make sure the options for F11 are highlighted 'YES'. Please let me know if this helps. If you need restore disks, let me know.
3answers
6helpful
11answers
Nokia 6600 License Key
IMEI 35666500043492
key 1579
imei 357932005812725
key: 37243
imei no: 359365005978790
key: 19736
imei 351546001742607
key: 20322
if it doesn't work try version 1.4
Aug 29, 2008 • Nokia 6600
3answers
I STUFFED IT UP
Many times, MP3 players will play music from an "Audio" folder. Try naming the folder "Audio".
Top HEWLETT-PACKARD Computers & Internet Experts
Marvin
Marvin
Paul Bade
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
