SOURCE: when powering up[on land] it says transducer not connected
Disconnect cable from back of unit clean the pin connections on the unit and on the cable. If rusty clean with Corrosion X are WD
IF it doesnt work replace cable Jim OMC Retired Mech
SOURCE: My 570 quit showing the depth and continues to
I had the same problem. It was the transducer.
SOURCE: when I power up the
Call our customer service group and they will be able to help you out. Our number is 800-633-1468.
Joby @ Humminbird
SOURCE: I have a 190c installed
Hi, According to your problem, first make sure that you have mounted
the Transducer inside the Hull or Transom.
Check the transducer cable. Set the video resolution. Master reset may require
for the Fishfinder.
SOURCE: Not getting correct readings from
you need to mount it or stop it lifting off the hull tthen move with it sucured
