Question about Hayward SAND FILTER, PRO SERIES
I have an above-ground Hayward sand filter that I'm trying to hook up. I can't remember how to connect the hoses and have been trying to find a diagram (photo) that shows. Can you help?
John Prohaska
    President:
  • Hayward Master
  • 1,378 Answers
If you look closely at the plastic near the threaded ports you will see Pump, Return and Waste. Pump is the hose coming up from the pump discharge, return goes back to the pool or to a heater or other accessory if you have one and waste is the backwash line.
John
Posted on May 03, 2011
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
We need to change the sand in our filter ,it is a sw256t hayward ,but dont know how to remove other sand,does anyone know how?
Once you have the plumbing disconnected and valve removed,
Use a shop vac. Works well.
Once the sand is almost all removed, you can tip the tank over & rinse out with hose for the rest.
Jul 28, 2012 | Hayward Pro Series 18" Above Ground Pool...
Sand filter losing prime
You will see NO leak if the pump is on.
But once the pump is off, then you may see a leak.
Jul 23, 2012 | Hayward Pool & Spa
Show how to hook up hoses to sand hayward filter
Here is a copy of the users manual for these pool filters. Page 5, specifically, should help you because it has a diagram of the filter and where the hose connections are. It should have everything you need to get it set up properly.
http://www.backyardcitypools.com/images/hayward/side-mount-filter-manual.pdf
Jul 12, 2011 | Hayward SAND FILTER, PRO SERIES
How do I hook the bug to my sand filter?
You should check out figures 6, 7, and 8 in the owners manual for these pool cleaners. There are detailed pictures that show you how to connect the cleaner to the filter.
http://www.backyardcitypools.com/images/Hayward/Aquabug-Manual.pdf
Jun 25, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
Need to know which is inlet and which is outlet connections
Take a look at the owners manual for these pool filters below. They have a diagram that should help you figure out where to hook your connections up.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Jun 19, 2010 | Hayward Pro Series 21" Above Ground Pool...
Sand in backwash
You need to replace the seal in the head unit of the filter.. The sand should be replaced every three years or buy a cleaning solution.
Jun 17, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward SAND FILTER, PRO SERIES Logo
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
