Hi, the calibration sheet being referred to was sent with the printer, it's a piece of cardboard ( white with one corner missing). Please check the packaging if you still have it, otherwise borrow one from a friend. All the best.
Dont worry, this is not error! The printer is asking to continue with calibration procedure:
After a few seconds, the printer prompt for the black card when it displays "INSERT BLACK CARD" so, Feed the black card through the front of the printer (where the card exits through) with the black side up, until the printer takes the card in automatically. You will get one of two results: a. RIB SENSOR PASS. Indicates the ribbon sensor was calibrated successfully.
It sounds like the image stabilization/calibration has not been completed properly, remove 3 print cartridges ( any) switch unit back on and wait for display to ask for other cartridges, - insert when asked and allow the machine to complete the calibration, alternatively use the menu function and look for image stabilization under diagnostics and activate.
Not exactly sure what you are asking but if the problem is that you are getting fine lines down the paper (the copy is ok though) then take a real close look atr the glass platen (the plate glass in which the paper goes on. Assuming you are using the ADF (Automatic Document Feeder) area. This area is usually about an inch wide by 8.5" long. Look for either "White out" or black ink on the glass (it can be as small as a dot) clean this mark off with glass cleaner and you problem will be solved. Sometimes it helps to orientate your copy with the line on it to the machine to locate the mark causing the issue.
Open the tray and make sure the green paper lever is set to letter mark, both at the bottom of the paper and the one on the side. And yes, if you haven't used it for 3 years, you should clean the dust that settled inside your printer over time.
clean out ur printer u possible have paper sticking inside ur printer follow the help line...if printer is clean it will work well again.....clicking noise indicates ur printer needs cleaning out
this is problem with cassate please add paper in cassate.
* in cassate at last one green color botton is there set that one as per paer size
* after remove the cassate see at front left down there one white color sensor is there this sensor senseing the cassate availbilty please check that one
