Try cycling your router (unplug for 10 seconds then plug back in), after you've done that test your xbox live connection. If it comes back good try logging back into xbox live, if it doesn't try doing the same thing again but this time start with the modem, after the modem cycle the router, then test your xbox live connection again and it should be working.
You may have a problem with your internet connection. Try and reset your router and try again.
there are series of problem in xbox 360 which
can be solved without much technical knowledge ........ your problem belong to
that so dont worry i will give you the link to download the xbox repair
guide that will help you a lot........
all the best.........
click here to download
