Hello & Welcome to FixYa
F4 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. However, I believe it is the sensor as the problem is only with bottom oven. Please get back to me if you have any other questions.
Kevin
