You could try and switch outlets and see if that helps. If it continues to do the same thing access the T.V. menu from your remote and check to make sure you don't have a sleep timer set. If there is no sleep timer and switching outlets doesn't help then my guess (from my own experience) would be that it's probably on its last leg and would require a repair. If it does require a repair then you would probably have better luck buying a new T.V.
Testimonial: "I can't speak, so getting help is always a hassle, especially since I only have a fixed disability income. I very much appreciate the answer I got."
