Question about Kenmore 54501 Dehumidifier
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Posted by wshields480 on
Rich Landrum
    Brigadier General:
  • 4,736 Answers
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
Posted on May 03, 2011
Testimonial: "Thanks. You've confirmed what I thought was how a dehumidifier works. (Reverse of a refridgerator) However I never "
  • Rich Landrum May 04, 2011
    That's a good analogy. Also, thanks for the 4-Thumbs Up Rating. I really appreciate it.
My dehumidifier kenmore model 580.52650 is working fine but turn off and turn back on every three minutes it is this dangerous, any solutions ? THANKS.
I think the problem may be caused by the humidity extraction level you have the unit set on. (i.e. It's set to high). Lower the humidity extraction level to 35%. This will allow the unit to run longer and extract more humidity, before it either shuts off, because the humidity level has been reached or the bucket is full and needs to be emptied.
Don't forget, the air intake filter should be cleaned regularly.
Hope this helped you. Please let me know.
Jul 08, 2011 | Kenmore 54501 Dehumidifier
I cannot change the set point on my humidity control. It is at 70%. If I press the up arrow i get 2 beeps and no change. When I press the down arrow there is no response at all. Is there some sort of...
The problem is, your trying to raise the humidity level, not lowering. These work in reverse of what you may think. Lower the level (Arrow Down) to 32% and it will continue to run, but will draw more humidity out of the air and will not stop until the water collection bucket is full or the humidity level reaches 32% or you turn it OFF.
When you pushed the Arrow Up Button, it was already on 70%, that's as high as it will go. But that means, you're trying to maintain a 70% humidity level. If it's Summer where you are, I don't think that's what you want.
Hope this helped you. Please let me know. Thanks.
Jun 24, 2011 | Kenmore 54501 Dehumidifier
I have a Kenmore 54501 Dehumidifier. Just plugged it in today and it runs but no water is in tank. What could the problem be? It worked great last summer and was not plugged in all winter.
You may have the humidity extraction level set higher than the humidity level in the house. Lower the level to 32 to 35%. Also, remove and check the air intake filter for dirt or clogs. Clean if necessary.
Hope this helps you solve the problem.
Jun 09, 2011 | Kenmore 54501 Dehumidifier
My dehumidifier is not collecting water what can i do to fix it? the model #99701
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 primary reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Kenmore 54501 Dehumidifier
Start up instruction for dehumidifier
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
Feb 16, 2010 | Kenmore 54501 Dehumidifier
Unit will not start. all lights on control panel light up, and the water catcher is in place.
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 31, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Jul 27, 2009 | Kenmore 54501 Dehumidifier
My kenmore 50 pint dehumidifier 54501 runs but it does not taking in water
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
Jul 18, 2009 | Kenmore 54501 Dehumidifier
Water is not condensing
Most dehumidifiers do not have an air filter and periodic coil cleaning is required. Remove the plastic housing and clean coils with water or air. Be sure unit is unplugged and dry before plugging back into the wall soket.
Jun 27, 2009 | Kenmore 54501 Dehumidifier
Kenmore dehumidifier 54501 not filling with water
if your humidity level is not highin the house or room you are using it in your humidistat will shut it down try turnning system up to higher setting
Jan 07, 2009 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
582 people viewed this question
Top Kenmore Dehumidifiers Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
