That means you don't have a good DIgital INput (get it?) signal or bitstream. Correct the source's playback or connection.
It's on page 37 of the manual.
since you tried everything..let me give yu the ultimate solution
1.go to file manager and backup phone on memory card and remove it 2.go to settings<phone managment<factory settings 3.enter password and reset the phone 4.after resetting insert memory card and restore
maybe need to replace a new cartridge or chick you ink if not empty and din check inside your printer possible have a paper jump inside,, or try to remove completely the printer driver using the (ad and remover program) how to this go to the start menu din control panel you can see the ad and remove program,, and click uninstall your printer driver and din restart your pc to take effect and din install gain,,
thank you i hope i can help you.. have a good day!!!!!!!!!
it seems your MD unit is expecting a digital signal on the digital input causing this message to appear. You need to connect a signal source to the digital input
or
connect an analog signal to an analog input and select the analog input as signal source.
In both cases the DIN UNLOCK message will then disappear.
I'd say you have the digital input selected. The player does not see a digital signal and gives such message. Select the analog input and you should be able to record.
Din unlock means 'digital input is unlocked' meaning it is not receiving a signal on the **digita**l input you have selected. ( eg optical or single co-axial digital from another cd player etc) Check your connections and re-select the source using the front panel until you select the one you want. What are you recording from?
