Question about Canon Office Equipment & Supplies
Error Number 5200 Printer Error has occurred contact the service center
Posted by mafuz09 on
EJ Kudelka
  • 1,188 Answers
How Reset Canon PIXMA error 5200: The printer is turned off and plugged the power cord. Press the button STOP / RESET and hold, then press and hold the POWER button. POWER button is pressed, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed. Release both buttons simultaneously. Press the power button, then the printer will off Press the power button again, then the printer will be lit and ready for use.
If this does not solve the problem, here is another method:
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working.
Posted on May 03, 2011
Will not print. What does error 5200 indicate?
See: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5200
5200/P08 - Orange and green light blinking 8 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
Jan 18, 2016 | Canon PIXMA MX340 Wireless Office...
I receive an Error Code 6901 on my MX725 printer, what can I do?
It usually means that it needs to be cleaned.
Take out the cartridges and look to see if there is build up.
That normally causes the error.
Apr 17, 2015 | Canon PIXMA Office Equipment & Supplies
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Nov 24, 2013 | HP LaserJet 5200 Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Error Number : 5200 A printer error has occurred. Turn the printer off and then on again. If this doesn't clear the error, see the user's guide for more detail. I have tried turning it off and...
Hello and Welcome to FixYa!
Error number 5200 is a
service error. To solve this error follow the given steps:-
  1. First of all unplug the printer
  2. Open the top and bring the ink cartridge holder to the middle
  3. Raise the gray bar and remove the print head assembly with the cartridges in it
  4. Lower the gray bar with the head missing and close the top with the head out
  5. Restore the power,wait till the printer starts
  6. It will tell you to put in the cartridges, Put in the cartridge
  7. Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
Any more confusion, queries or for further assistance, I am here to help.
I hope this solution helps you
Thank you for using FixYa!
Jun 07, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Error number: 5200 A printer error has occurred. Turn the printer off and then on again if this doesn't clear the error. See the use's guide for more detail.
Issue: ERROR: Error code 5200 appears on the computer screen
Solution: The IP2700 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. If you feel your product might require service, a Technical Support Representative will be happy to answer any questions you may have and explain the service options available to you. You can contact Canon through their email link or phone numbers listed on their website:
http://www.canon.ca/inetCA/products?m=gp&pid=1262
Although it does not say it in the explanation it is possible your ink pad has reached capacity and requires replacement by a technician.
If you wish to attempt changing the ink pad yourself there are some video demonstrations on You-Tube for canon printers. Here is one link but there are similar videos that you may wish to view before attempting. Trust this is helpful. Don't forget to vote.
Dec 14, 2010 | Canon Pixma iP2700 InkJet Photo Printer
My Canon PIXMA iP4000 stopped working with the following messages; (1) error no. 5200 a problem has occured with the printer mechanism (2) cannot print properly because of print head overheating (3)...
first of all the error message is correct when it said that the print head is overheating, this may be cause or triggered by a full waste ink.
will be able to see the steps on how to do it when upi download the Service Manual for your printer.
Canon IP4000 Service Manual
Aug 12, 2008 | Office Equipment & Supplies
1,255 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
