Question about Fujitsu fi-5120C
Scandall 21 & Adobe
At our company we use acrobat 7.0 standard. When using Scandall to scan to a pdf adobe will open up and the scandall program will freeze. You can save the pdf in adobe but end up having to go through task manager to close scandall. I tried adobe updates and even after installing and rebooting the same update appears. Any suggestions?
Posted by rachilly07 on
2 Related Answers
Anonymous
SOURCE: Can't setup ScandAll 21 on fi-5120C
why do you want to use the older version, the new version has much better driver support and actually works with the event buttons on the scanner.
Posted on Jun 02, 2008
Anonymous
SOURCE: HP ScanJet asking for DPE
Where is DPE? - When I tried to save a pdf-file (black/white), I was asked this question and my application folder opened automatically. I am using Mäc Leopard and hp g 4050 scanner. Who can help me solving this problem? I don't even know, what DPE means. Martin (Morogoro-TZ)
Posted on Nov 28, 2009
How do i download Adobe Acrobat x Standard for Free?
Acrobat reader is free. Acrobat pro is not free.
There are other free programs to create PDF's. Really, Adobe is offering the readers for all systems for free. Be aware sometimes PDF files are password protected. You even can't read them with acrobat reader, if you don't have the password. Just visit the Adobe website to download a free version for your system.
Now you can get the 11 version here:
Adobe Adobe Reader free PDF viewer download
Nov 22, 2014 | Cosmi Perfect PDF Creator Full Version for...
Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
I am unable to open pdf's
Go to Adobe's web site and download the latest Adobe Acrobat "Reader".
Sep 24, 2009 | Adobe Acrobat 6.0 for PC
Suddenly all my pdf docs are opening in Adobe reader instead of Acrobat Pro. Even the Acrobat.exe file in my C:Program Files\Adobe\Adobe Acrobat 7.0\Acrobat folders opens Adobe reader instead of Acrobat...
Go to My Computer. Tools > Folder Options > File Types > Then Browse PDF Registered File Type . If you can see " Details for PDF extension " and you can see a change button, you can click that button and browse for your Acrobat Pro main program .
Aug 18, 2009 | Adobe Acrobat 7.0 Professional
Scandall 21 Automatically Saves Scan As Temp Fil
go into the settings on your computer and change the setting to save all scans
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Fujitsu fi-5530C Scanner
I installed acrobat 6.0 standard on my pc, I
Uninstall the Acrobat Reader 7.0
You can also right click on a file and select Open With, then choose Adobe Acrobat 6.0 Standard.
Feb 21, 2009 | Adobe Acrobat 6.0 for PC
May 23, 2008 | Fujitsu fi-5120C
Fujitsu fi-5120C Logo
448 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Vincent G
Vincent G
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
