Try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
SOURCE: DVD eating discs
It's obvious that the DVD is stuck in the player. There's only one way to get it out! You have to open the DVD player. If you have never done this before, I don't recommend that you do it.
SOURCE: dvd will not play on my govideo dvr4250
Do you hear it spin up or not?
and if not the laser is in it's retracted
state when it should be up and reading
It probley out of timeing with
respect to the tray
you can fix this but you will
have to open it up to do it right.
SOURCE: dvd won't play my dvd's. keep saying no
Memorex MVD2016BLK Progressive Scan DVD Player, Black (Electronics)
suddenly began having problems - stuttering, claiming 'wrong disc', stuck in standby and unable to get it unstuck....was torn between throwing it out the window and buying a special cleaning disc. Instead went to the Memorex site and found the reset procedure, which WORKED! Try this for your frozen MVD2016. Reset procedure:
1 Press and hold power button
2 Unplug unit from electrical source without releasing the button
3 Keep holding button for 60 seconds
4 release and reconnect.
5.watch your DVD.
Read more: http://wiki.answers.com/Q/How_do_you_fix_a_memorex_DVD_player_mvd2016blk#ixzz1giqZM7I7
