Hi Ramdatt Sookchan, I could have a problem with the LCD panel, try disconnecting one of the Flex tapes from the T-Con board to the LCD panel and see if half of the image appears, do the test by disconnecting one and then reconnecting and removing the other
If a screen appears in any of the tests, the problem is in the LCD panel
Try and comment
Greetings Franco Dosil
Hola Ramdatt Sookchan, podria tener un problema en el panel LCD, prueba desconectar una de las cintas Flex de la placa T-Con al panel LCD y f?jate si te aparece la mitad de la imagen, haz la prueba desconectando una y despues reconectando y sacando la otra
Si en alguna de las pruebas te aparece media pantalla, el problema esta en el panel LCD
Prueba y comenta
Saludos Franco Dosil
You have a power supply in the monitor that is failing. This is a known issue with these great monitors. It is a simple 20 minute repair. We have a step by step repair guide for ts model posted on our site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ The repair involves replacing 5 small parts called capacitors. If you don't want to do the repair yourself we do offer a repair service for this model, the repair service runs $32 plus shipping.
Your monitor has a failure in the back light power supply, this is a common problem in this model after a few years of use. The repair is easy and only takes about 20 minutes but it does require soldering to replace 5 small parts called capacitor in the power supply. We have the step by step repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you don't want to do the repair yourself we do offer a repair service, this runs $32 plus return shipping. You can get more information on this service at: http://www.ccl-la.com/blog/index.php/service-request-form/
We hope this helps, if so please rate our solution.
Check the caps in the power supply first. Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also. http://en.wikipedia.org/wiki/Capacitor_plague http://www.badcaps.net
Most common failures in SAMSUNG and other LCD monitors are due to bad caps, that will be the first thing to look for inside. Please see SAMSUNG albums so you will know what to look for inside.
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: [email protected]
I hope this helps, if so please rate our solution.
You will need to take a small flat blade screwdriver and insert it between the two halves of the case and gently pry the two apart. There are latches around the case that just need a little pressure to release. Once you get a few released the rest will pop open as you pull the halves apart. We have some pictures posted on our web site at: www.ccl-la.com Look in the monitor repair section. THere are several repair guides for different brands with pictures of what the release latches look like. If you have any questions just call us at: 318-447-9040
I hope this helps, If so please rate our solution.
Please check/ replace T-Con board (lcd controller board) that is located at top center of lcd panel rear side. It would be covered with metal shield and after removing that metal cover, you will access it. Thanks.
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy Corporate Computer www.ccl-la.com Over 21 years of computer and printer support/repair
The Samsung SyncMaster 940MW monitor has an issue with the power supply # IP-46135T going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: [email protected]
