Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printer cartridge carrier is stuck
Hi, saw your response to someone else about the printer cartidge.
My problem is this.. I've been using my printer for quite a while and have changed my ink cartridges many many times.
My printer says I need to change my ink. I have new ink, but the carriage is stuck this time. I have a fax in memory and can't print it. I don't want to force the carriage.. so what do I do?
  • Anonymous Aug 11, 2008
    Never mind I fixed the problem. I found a button for refreshing the printer head.. works fine now.
  • bareias-2962 Aug 14, 2008
    how clean head?
5 Related Answers
Anonymous
SOURCE: Printer Problem
This did NOT solved my flashing led (15 times) also magneta led is off and when i re-install the cartridge its just a second on, and the flashing led is back 15x !! it driving me nuts..
How do you got this solved?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Posted on Dec 28, 2007
Anonymous
SOURCE: Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Posted on Mar 07, 2009
Anonymous
  • 291 Answers
SOURCE: Changed ink cartrigde and printer no longer printing.
microsoft logo is in colour and so its printing while everything else on test page is black so its not printing. the problem is common.you need to do automatic deep cleaning for the ink flow to start once you install new cartridges.go to printer maintanance option and click the option deep cleaning .it will pull out the ink in printer head and it will start working.sometimes also requires cleaning twice. thanks and do not forget to accept the solution.
Posted on Apr 03, 2009
Anonymous
  • 113 Answers
SOURCE: black ink cartridge is leaking and black line is running down back of page
YOU CAN TRY PULLING THE CARTRIDGE OUT AND WITH A CLEAN , VERY SOFT CLOTH , CLEAN THE HEAD GENTLY ....SOME CARTRIDGES ARE JUST FAULTY ....HAVE YOU TRIED RETURNING IT OR GOING TO CANON SITE AND TROUBLESHOOTING ?
Posted on Jun 02, 2009
Anonymous
SOURCE: Canon MP530 print head malfunction
I had the same problem with my printer. There is a switch that tells the printer that the cover is open or closed. Unplug the printer. Open up the printer cover and look on the inside right side edge. About half way back, you'll see a 3/4 inch by 1/2 inch hole where this switch resides. If you put your finger into it, you may be able to push on a lever and it will go down. It should spring back up when you pull your finger out. If you can feel the lever but it just sits at the bottom then there either this lever is broken or the spring fell off.
The problem with my printer was the spring had popped out. To access the switch, you'll need to remove the right side cover. Do this by removing the two screws in the back on the right side. Open the printer cover and find the third screw. It is located on the right hand side, near the front of the printer, on the top. Remove this screw and pop out the cover and see if you can find the spring that is attached to the lever. Make sure you do this in an area that if a small piece fell out you could find it.
Look at the switch and lever. If there is no spring attached to the lever then it is most likely the problem, otherwise the switch may be bad or the electronics inside the printer. There is a hook on the lever and one on the printer. Reconnect the spring and it should fix the problem. I found my spring had completely fallen out and fell on the floor when the cover was opened. It is possible that this spring if fallen out can fall back inside the printer so you may have to shake the printer to find this little spring. It is about 1/2 inch long. Hope this helps.
Posted on Sep 10, 2009
Replaced Ink carts on Epson R380 with EPSON ink cartidges - printer says "ERORR: Ink cartridges not recognized'. [?] have replaced these several times in the past with the same type dart with no...
Turn the printer off, take out the cartridges, turn the printer on, reinstall cartridges. Printer reads cartridges as new.
Why this happens? I don't know if the rumors are true but check out this website and you'll find out.
Jul 20, 2011 | Epson Stylus R380 InkJet Photo Printer
Hi, I have a problem with my printer... I refiled the cartridge and the computer says that is still empty. Sorry for my English.... Pls help me if you can...
Hi
Found this, think it's a good explaination.
"HP Printers internally keep track of your cartidges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. However, most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printer has the cartidge's serial number stored in memory. This will reset it."
Hope this helps
Jun 10, 2011 | Office Equipment & Supplies
The red light is always on i changed the cartidges and put papers but still nothing hapening my computer can read it but i cannot print because of the red color showing
The problem might be the powersupply. You should have this checked by someone qualified as doing it yourself can result in an electric shock
Goodluck
Mar 09, 2011 | Samsung CLP 315 Laser Printer
Hi, i cant find where to change my ink cartidge for my canon pixma MP480 printer
just open the cover on top catridge will come to center and remove it.
just open the cover .when you open the cover cartridge will come to center just pull all the cartridges one by one don’t make pressure too hard it will come easily if you put more pressure and try to removing it and it is not come out then don’t do it may be you doing wrong . let it be and take help from some one who using printer and know how to fix the cartridges.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Canon Pixma MP480 All-In-One InkJet...
Menu says right cartidge missing
hi,
This problem may also be due to cartidge holder .
clean cartrideg holder with moist cotton with petrol or some other cleaning liquid as nail polish remover. clean properly the cartirdge socket and mainly the contact point of cartridge socket
Aug 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Not printing in black
if u r used hp all in one or another then don't use duplicate ink cartidges. let make possible for u for using. boil a half glass of water, not too hot then after that drop the cotton in normal hot water & then clean the cartidge with this silly cotton on there when cartidge supply ink to printer, after some time get a wet cloth or cotton & clean it with wet clothe & adjust t=in the printer. i m sure ur cartidge will work. if ur problem not get solved then call me any time on my cellular no. +919876388918, i will try to solve ur problem with different way.
thanks alot,
sanjeev .
Aug 18, 2009 | HP Officejet 5510 All-In-One Thermal...
Changing ink cartridges
Hi.. Log on to the Canon website.. The printer manuals are in PDF Format at their site.
Thanks
jim
Feb 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cartidge dell not working on dell 1700 laser printer
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Jan 03, 2009 | Dell 1700n Laser Printer
Epson RX580 can't change ink cartridge
well..sounds like your new print cartridges are not too compatible..I recommend you get the right ones
Aug 19, 2008 | Epson Stylus RX580 InkJet Photo Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
