Question about Sony VAIO VGN-NS135E/S Notebook PC
My VAIO doesnt seem to charge up when connected to the power supply button at times it works then power depletes very quickly.
  • pwrightosmen May 03, 2011
    Hi.
    When you plug in the power supply do you get a charging light?
    Master:
  • 340 Answers
How long did your Sony VAIO battery been used? Li-ion battery's life is about 2 years. And you can do a battery capacity correction by your VAIO's Battery management software and to see that if the problem get better. else you need a new Sony VAIO battery.
Posted on May 03, 2011
6ya staff
SOURCE:
Tablet boots with power supply connected but when on battery power alone when pressed the power on/off button lights up with the hdd light and then goes off then on then off about 5 times.
You need to change the battery, the machine may well show 97 percent but the battery will deplete overtime purely because of t the number of times they are recharged. This is particularly so on newer batteries.....such as li-ion cells. The method of depletion can be deceiving, showing high charge but one that cannot be retained.
Buy a battery, (ies,) from a reputable manufacturer.
At worst you will have a spare
Jul 08, 2015 | Samsung NOTEBOOKS ATIV Smart PC 500T...
Shuts down quickly on fully charged battery. Battery problem or laptop problem?
Most likely processor problem. If battery is good and power supply is working.
Oct 06, 2009 | Sony VAIO VGN-AR150G Notebook
The power button doesnt seem to be working
It sounds like a short in the button itself. If you have a soldering gun, take it apart and resolder the connection. This is typical for Acer laptops.
It's either the button itself or the jack where the power supply plugs in. It's not real difficult.
Jul 15, 2009 | Acer Aspire 5500 5570-2609 Laptop
My player wont turn on. The computer reconizes it for a couple seconds but then the player shuts down. The play/pause button blinks but the olayer doesn't seem to be charging. The reset button is broken....
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter (separately available).
  2. Check the display for the charging icon battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  3. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Creative Labs ZEN V Plus MP3 Player
My Zen v plus won't turn on. The reset button is broken and it will have the play/ pause button blinking but it doesnt seem to be charging. The computer reconizes it for a couple seconds but then the...
    • If the battery is fully depleted, the charging icon may not be displayed.Cup the player in your hands to check that the blue power LED behindthe Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
Ifthe player does not indicate a charge, or will not power on after atleast 6 hours of charging, please contact Customer Support.
Creativerecommends updating your ZEN V or ZEN V Plus firmware to take advantageof new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
SONY VAIO BATTERY CHARGING
This is not a problem, this is a designed function to increase battery life. To adjust this, go to "vaio control centre", and then power management. Inside this is battery care, here you can adjust the settings or de-activate this function.
Firephox
Oct 06, 2008 | Sony VAIO VGN-A150 Notebook
Turn on problem
Some times, the charging cable from the laptop will not charge a fully depleted battery. If you have not already done so, try charging it using the wall charger that came with the phone.
Hope this works!
Aug 29, 2008 | Apple iPhone Smartphone
Sony VAIO VGN-NS135E/S Notebook PC Logo
168 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
