1. From OFF, press and hold the On/Off (8) button for 10 seconds until the Bluetooth Indicator (4) turns blinking red/blue.
The handsfree kitis now in pairing mode.
2. While the handsfree kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function and execute a
Bluetooth search. (See your phone's manual.)
3. When the phone displays the list of Bluetooth devices, select ST
BUDDY.
4. If the phone asks for the password/pin code, enter 0000 and pressOk.
5. The handsfree kit is now ready to use.
Sep 16, 2015 - How To Pair The Scosche boomBOTTLE+ Portable Speaker ... Turn on your device's Bluetooth Menu to search for and connect to the boomBOTTLE+. ... only one speaker, place the speakers in "S" (stereo) position and turn off ...
You need to pair with the gps first before you can use as handsfree. Turn on BT in your iphone and start to pair with the gps, there may be a code showing at the gps screen and then type the code on your phone, then they paired which means you can start to use it. Good luck.
The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
When using your S9 for the first time, follow these steps to pair (connect) to your Phone: Important: If you are pairing separate Bluetooth devices for handsfree calls and streaming music, it is recommended that you pair your S9 with your handsfree device (phone) first. 1 Ensure the Bluetooth feature is enabled (turned on) in your phone.
2 Turn on your S9 by pressing and holding (|) button until the indicator light flashes three times in blue. After a few moments, the indicator light will be steadily lit in blue to indicate your S9 is in pairing mode. 3 From your device, perform a Bluetooth device discovery/search. . When pairing your S9, use the following steps to perform a device discovery from your phone: After accessing the Settings Menu, go to bluetooth. to add a new device, tap [New]. 1. Tap [New] key to search the device that can be connected and which is within range. The phone lists Bluetooth devices it finds. b Select Motorola S9. c Select OK or Yes to pair your S9 with your phone. d Enter the passkey: 0000 e Select OK.
When your S9 successfully pairs and connects to your device, the indicator light displays blue with 10 quick purple flashes. If wearing your S9, you will also hear an audio tone indicating successful pairing and connection to your device. 4 To verify your S9 has successfully established a handsfree calling connection with your phone, dial a phone number you want to call and press the Send key on your phone. When successfully connected, you hear ringing on your S9. A Bluetooth Handsfree Phone (HFP) connection is now established with your phone
Press and hold the 'Call' button on the Nexxushandsfree for 5 seconds. It will then go into Pairing mode. Set your phone handset to search for Bluetooth devices.
