Question about LeapFrog Turbo Twist Fact Blaster
How do I get downloads? Do I need an adaptor cord to download?
Posted by cinnamong605 on
Iron
  • 3,018 Answers
  • You have to order a Leap Link Data Cartridge or (Leap Link Upgrade Kit) and download any updates onto that from Leapfrog's website.
http://www.amazon.com/LeapFrog-80070-Leap-Link-Upgrade/dp/B00004TFFZ http://www.ecrater.com/p/5413339/leapfrog-leap-link-upgrade-kit
  • Updates available here.
http://shop.leapfrog.com/leapfrog/
Regards, Tony
Posted on May 03, 2011
Need driver for Acer ethernet adaptor
try going to the acer support page and looking for the driver download----also, you can try driverguide.com. they are all free downloads and you might find it there
Apr 25, 2010 | Dell Intel Ethernet Adaptor 0000921206...
I recently reinstalled Windows XP onto my computer and when I did it didnt recognize the driver for network adaptor. How do i get that adaptor driver?
Go to the Internet site for that adapter's manufacturer, and locate the drivers for that exact driver. Then download it and install it, and it should work fine.
-a.
Dec 06, 2009 | Computers & Internet
Ga how to download games
You'll need a USB Type-B cord, or a MS Duo Adaptor to transfer files from PC > PSP... PSP PC.
If you're using a USB cord, connect both ends to PC & PSP, go to Settings > USB Connection.
If you're using a MS Duo Adaptor, insert your MS into the Adaptor, then insert the Adaptor with the MS inside it into a PC.
There should be a folder in the root of ya MS called ISO ... in capital letters.
Drag & drop games into the folder! SIMPLE!
Nov 19, 2009 | Sony PlayStation Portable (PSP) Console
I need a power cord
go to makers web site click support and input model number and serial number then download manual.
spec for power will be in manual or maybe they sell psu unit for modem
Jul 30, 2009 | Arris High Speed DSL Modem
Power cord not working
Try unpluggin the power cord and check with battery.
Check whether battery is charging with the power chord on.
Try with a different wall socket.
If this does not help.
Try with a different power chord of the same kind and check whether it works.
If yes, the power chord is the ussue. Best would be to replace it.
else
Try your power chord in a laptop similar kind and check whether the other laptop works fine.
Try juggling the power cord and check whether it gives supply.If yes then check for AC adapter for any damages or cuts. If any is found the contact manufacturer for replacement.
else Main board is the issue.
But before this I would request you to go to the website and check for Updated BIOS and updates for chipset driver.
If any is available then download and install.
Check with your AC adapter if it works, Good, else I would request you to contact the manufacturer for a Main board issue.
They would replace the main board if under warranty.
Jul 22, 2009 | IBM ThinkPad T43 Notebook
Needy
hi....
the cable looks like a usb to mini usb ...i bought a usb adaptor set from local ASDA / walmart store with 5 different interchangeable plugs
a supplier like rs components may have them also
hope this helps
Nov 07, 2008 | SanDisk Sansa m240 MP3 Player
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    HP nc8000 LAPTOP DISASSEMBLY ETC....
    I would try a new power adaptor cord 1st, they go bad alot and I have been on calls to soder the DC power socket many times, when it was simply a power cord problem.
    If a new cord does not work the assembly manual can be downloaded from HP at this address:
    http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00803690/c00803690.pdf
    Apr 02, 2008 | Computers & Internet
    LeapFrog Turbo Twist Fact Blaster Logo
    188 people viewed this question
    Top LeapFrog Toys Experts
    Marvin
    Marvin
    Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
