There are a few different causes for this. All of them leading to the "spooler" service to stop running.
The most common remedy is to just reboot the computer. If this fails, there may be a corrupted document in the spool queue that is crashing the service repeatedly here are the steps to clear it out:
For Windows XP (your computer says "start" in the bottom left)
1. Go to the "Start" menu and click "run"
2. in the window that comes up enter "net start spooler"
3. Try printing again.
4. If the problem continues then:
5. Click "start" and "Run" again.
6. enter "C:\Windows\System32\spool\PRINTERS" and click ok and delete any items in there.
7. Close that window.
8. Restart the computer.
You should now be able to print.
For Windows Vista or Windows 7:
1. Click the blue "Start" orb
2. In the search box enter "command"
3. The computer will return with several items
4. Right click on the black item that says "command prompt"
5. click "run as administrator"
6. in the black window type "net start spooler" and press enter
7. try printing again, if it fails continue to step 8
8. open the blue start orb
9. in the search box enter "C:\Windows\System32\spool\PRINTERS"
9.5. If you get a permissions message click continue
10. delete all items from there.
11. back in the black command prompt box, type "net start spooler" again
12. You should be able to print.
If you still cannot print, you may have one or more corrupted print drivers. In this case you will need to delete and re-install your printers from the computer using instructions from the manufacturer.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the
print spooler service)
2. type in NET START
SPOOLER (this will restart the print spooler service).
Try to print a document again to verify that the problem is fixed.
1. Browse to Start
-> Run... and type in "NET STOP SPOOLER" (this will stop the print
spooler service)
2. type in "NET START
SPOOLER" (this will restart the print spooler service)
Try to print again.
