Hi donmorrill
Dosen't sound like the board at all. Sounds like you have a connection problem front to rear harness. I have worked on many celebrity 2000's and have found a bad connection with symtoms like yours. In the rear you will find where all the connections are plugged in. Check each one for continuity. Clean all connections, also make sure the little metal connectors are intact in the anderson connectors. But you do have a harness problem.
Good Luck
mimobility
Wiz
