Question about Antec (NOTEBOOKCOOL) Laptop Cooler
My Lap top cooler stopped working. When I plug it up nothing happens...
Posted by kawesson on
Aaron Cooper
  • 73 Answers
The fan may have failed, you will have to replace the fan or cooler. Check to see if there are any loose wires.
Posted on May 02, 2011
Have an Acer M5-538P-5859 Lap top, that is 1 mo old. It is a Windows 8. It was left on with only battery power, for a number of days. I plugged in the charger and nothing happens--No lights on, no p
If you let the battery charge for about ten hours it might work. If you just want to see if the computer will work remove the battery and try with the charger plugged in. If you don't need to carry the computer around a battery is not needed. Some batteries will not recharge if they have been discharged too much. If you are going to use it with a battery I suggest that you set your power setting to turn the computer off after a period of unuse and this problem won't happen again. Check Ebay for a battery replacement.
Oct 30, 2014 | Computers & Internet
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
All my saved pictures have been deleted and the screen continually goes blank
Greetings and thanks for the question, there are various reasons why this happens. Without having your computer here to see what is going on is anybody s guess on how to repair it. If I may offer some suggestions. Since I also do not know what operating system you are using I will assume it is Win 7.
I would personally go to control panel and check my power options to make sure I do not have the settings set you close display or sleep mode or anything set to soon to close your machine down. Often times people have these set to go off there are defaulted usually to save battery usage and your lap top from getting to hot and shutting it down. The thermal switch may be activating sooner than normal. What some folks do is purchase one of those underneath fan coolers to keep their lap tops from getting to hot and constantly shutting down.
This can be the case have this checked out at least set the lap top for more time before closing down or turning the monitor off. Let us hope it is not more serious than appears. Like a lamp in the monitor going out. If it is new the lap top I would not worry about that issue because it is intermittent. Which leads me to believe it is a thermal or a shut down issue. Get the cooler fan for your lap top I recommend anyone that reads this post to also do this as well. Clean your lap top blow them out it is critical to do this to keep dust away and keep it clean.
Now there is recovery software which is free to download Click Here to check this out to retrieve lost files. Also important to get those precious memories separate off your computer and on to separate CD or DVD or storage USB stick so that when this type of thing happens you have not lost your precious memories. I hope this helps you. John
Jan 17, 2011 | Samsung NC10-14GW Notebook
How to repair my satellite lap top computer, which became suddenly black? and I re-started lap top and nothing happened
It would be impossible to diagnose your problem without more information.
You may need to take it to a repair shop.
Is your battery faulty?
Are there any lights on the laptop when yopu plug it in?
Have you checked the fuse in the power adapter?
Oct 14, 2010 | Computers & Internet
Computer just powers off while on the internet. All virus scans done battery good it just shuts off while I am playing games.
a lot of laptops simply run too hot inside .. if you actually use in on your lap or on a pillow or blanket then you may be blocking the air intake ports .. or they could be clogged with dust. the internal fan may not be working .. if you run it on a table top and still have the trouble then i have had good luck simply by putting "stick on" felt pads that raise the laptop a bit more off the table top .. also there is a laptop cooler .. its a platform with a fan or fans inside that blow air into the laptop and keep it much cooler .. those are worth while on many laptop brands because it keep it cool and extends the life of the computer .. the platform often gets its power from a USB port or seperate adapter ... one i bought at radio shack folds up to almost nothing for transportation .. and didnt cost much .. it also worked very nicely to keep the computer cool ..many stores carry versions of the cooler so you have a wide choice ... the ones i have seen range from $15 to $29 ... and the lower cost one turned out to be the best (on sale) .. the nice thing is that you can use the cooler in bed or on your lap since it has air intakes on the sides that are spread out so you cant stop the air flow even if you block some ports.
Nov 22, 2009 | Office Equipment & Supplies
Cooler plugged in to the converter--not working
The most common problem is the fan has failed. If you have the newer version, these fans can be found anywhere computer parts are sold.
Jul 09, 2009 | Coleman Electric Cooler 40 Beverage Cooler
ADVENT KC550P Lap Top scren
the pc is standing at command prompt, which means it is unable to find the boot.ini file required to boot into windows
When you say you pressed F8 did you keep pressing it until you got a menu saying Safe Mode,last known good configuration, start in VGA mode etc, if so use last known good configuration and let it reboot.
If still nothing then you will need the windows cd to perform a system repair.
Aug 20, 2008 | Computers & Internet
Hi i have an hp pavilion dv2000 lap top, i am trying to record my acoustic guitar into the comp. This lap has conexant high definition audio sound card inbuilt. However when i try and plug a microphone...
The mic may be muted on the computer. In XP, double click the volume control icon in the bottom right of the screen to get the mixer. If you don't see the microphone input, go to 'options' then 'properties' and place a check in the box to show it. Then make sure it is unmuted and the volume is up.
In Vista, right-click the volume icon and choose recording devices and make sure it is on and volume up.
Apr 23, 2008 | Computers & Internet
Antec (NOTEBOOKCOOL) Laptop Cooler Logo
238 people viewed this question
Top Antec Computers & Internet Experts
Dimitar Todorov
efs_perpends
efs_perpends
Anthony Ward
Anthony Ward
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
