Question about Audio Technica Audio Players & Recorders
SOURCE: Death of the Sandisk
Let's try this: take the battery out of the player and wait for a full 5 minutes. While the battery is out, please hold the power-on button for 10 seconds. After that, connect it to your computer (without the battery). Does it work when it's connected to the computer? Regardless of that result, disconnect it from the computer, then put a brand new alkaline battery back in, and see if it will turn on.
Posted on Aug 24, 2006
SOURCE: minolta dimage 7i fix
I just found a solution to my camera problem. It turned out to be the batteries. We purchases some Rechargable Duracel with a 2650mAh rating. After charging the batteries I put them in the camera and it started right up and was taking photos like when we first bought it. I have not been able to use the camera in almost 2 years and it turns out the problem was weak batteries.
So anyone that has a Minolta Dimage 7i and cant get it to turn on make sure you have at least 2650mAh rated rechargable batteries. The higher the mAh rating the better.
Hope this helps someone else. We are ecstatic that we can use our camera again. No more using my camera phone!!!
Posted on Jan 19, 2008
SOURCE: Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Posted on Aug 05, 2008
SOURCE: Wii USB not working
I had the same problem but i found out if you only have 2 remotes and you use them for the guitar and the drums the mic wont work.
you have to use one of the remotes for the microphone
first unplug your wii console then hook up the mic to the consol
turn the wii on and use the remote for player one to activate the game without the other instruments connected.
after you get the game started it will recognize the microphone. then connect the other remote to which ever instrument you want to use. you have to have three remotes to use the guitar the drums and the microphone
Jerry
Posted on Dec 27, 2008
SOURCE: My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Posted on Apr 09, 2009
Mar 10, 2015 | Korg Music
Dec 03, 2017 | Televison & Video
Dec 19, 2010 | Panasonic TCP50C2 50 in. TV
Jul 29, 2009 | Crown CE1000 2-Channel Amplifier
Jun 07, 2009 | Audio Players & Recorders
Jan 28, 2009 | Sony MDR-V500 Professional Headphones
Jan 13, 2008 | LG DU-50PX10 50 in. Plasma HDTV
Oct 30, 2007 | iRiver H10 MP3 Player
Mar 28, 2007 | SanDisk Sansa e270 MP3 Player
