Bosch SHU5316UC Dishwasher Logo
Posted on May 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SHU 5316 UC dishwasher by bosch. I think it is from about 1998 or 99. It blew a circuit breaker yesterday. I reset the circuit braker, but it won't even power on. It may have burned something out. We replaced the control board 2 years ago. Please tell us: 1. Is it worth fixing again, or just replace? 2. Any suggestios? Maybe the pump has shorted? THANKS SO MUCH!! Mark
DILLIGAF
Level 3:
President:
  • Master 1,140 Answers
  • Posted on May 02, 2011
DILLIGAF
Master
Level 3:
President:
Answers
1140
Questions
Helped
680939
Points
4145
Hi Mark -
There's no internal fuse in this dishwasher, so if there's no power you may well be looking at a new control unit and probably another major component as well, depending on what caused the overload or short. The most likely suspects are a burned out water heater element or circulation pump motor, or there may be a leak in the base of the washer that shorted something. You'd likely need to do a fair amount of testing to find the cause.
You can't really put a new control unit in and use the diagnostics program or the error code display to locate the fault/s as you'd be running the risk of frying another control unit. The cause of the short/overload would have to be found and fixed before replacing the control unit.
A new control unit is about $130-150, a new circulation pump motor is about $130 and a new water heater is about $110. Assuming you need a control unit plus one of the other parts, minimum cost for self-repair is going to be about $250 and $350 upwards if you call a service technician.
12 years is a fairly good average for a Bosch depending on usage, water hardness and how well it's been maintained. If it was my washer and it needed any 2 of the above parts replaced, I would buy a new dishwasher.
If you want to investigate, you're going to need a Torx T20 screwdriver for dis-assembly and a multi-meter for electrical testing. You need to start by checking whether there is 110v at the on/off switch, then power to the control unit when the power switch is on. If there's power to the control unit and the washer is dead, you're definitely going to need a new control unit.
If you remove the right side panel (when facing the door) you can test the circulation pump motor and the water heater for resistance. The water heater should read about 10-11 ohms if it's good. Not 100% certain on the circulation pump motor, as they've used different types/configurations of motor over the years. I think this one should read about 0.5 ohms if it's good. If you want to take a reading, I can check that for you . . .
That's about as much as I can tell you based on what's known at the moment. Let me know how you want to play it and we'll go from there. You can reply to me by clicking on "Add a Comment" below your question.
Hope this helps.
Regards, BElectric
Ryan Pries
Level 2:
Sergeant:
  • Expert 257 Answers
Ryan Pries
Expert
Level 2:
Sergeant:
Answers
257
Questions
0
Helped
69350
Points
791
Sound like water got on to the motor, probably ready for a new dishwasher. Sorry
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
I have a built-in Bosch dishwasher SHU 4302 UC. It no longer drains the water out at the end of all the cycles. I have tried everything mentioned in the booklet (make sure water is hot, use the jet-dry...
The problem is a solenoid on the bottom of the unit. It is a small black cylinder next to the pump. It operates the valve that changes to the drain cycle. You can probably order one from Bosch
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
I have a bosch dishwasher model # I believe is SHX4AP05UC it keeps tripping my braker in the middle of washing wont complete a cycle any suggestions?
Adam, in order to help you, you must provide me with more info. What size breaker is tripping. What does the maufactor's manual reads about what size circuit it must be plugged into. If your house is a little old you probably have a 10 amp breaker that is tripping. If so than the manufaturer states theat it is recomamded to place it onto a 20 amp breaker. Only switch out the 10 map breaker to a 20 amp breaker if your the wire from the breaker is a 12 gauge wire.
Do not put a 20 amp breaker onto a 14 guage wire because it will most likely melt the insulation due to heat whichwill expose the bare copper wire which could lead to burning your house down.
Dishwasher without power
Check the electrical source. Possibly the breaker blew or he plug went bad.
The electrical load varies drastically during a cycle due to heater, motor, etc. If the breaker blew, ONLY reset it ONCE to try as there may have been a serious problem within the dishwasher. ALSO if the unit shares the power with another device that could cause the problem.
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Bosch dishwaher shu 4322 uc/u12
remove outer door skin and kick plate at base pump will be on view turn off power look carefully at pump you will see a lever you have to cut away a small section of plastic on lever to be able to push it inwards pump then twists off anticlockwise is a bayonet fitting like a light bulb.
hope this helps
Timer runs down to 1 min and just hums water covers the bottom
need more info on problem does it start washing then run down and hum or what
2answers
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
