Question about LaCie Computers & Internet
LaCie Ethernet Disk mini stopped being recognised
I have a lacie ethernet disk mini nas drive connected to my imac via ethernet. it was working fine but has now stopped. i am using mac os x (leopard vesion) i have ran the ip configirator but it is not seen.
I have forgotten the ip address of the drive so i am unable to access it at all.
Have you any idea how i can sort this problem.
Cheers
Karl
Posted by karlbartlett on
4 Related Answers
Anonymous
SOURCE: Lacie ethernet disk 1TB makes sound and not start properly
Is the HDD connected properly inside?
Posted on Mar 25, 2009
sys_admin
Milind Shetti
  • 829 Answers
SOURCE: I changed to a static IP address on my lacie-d2
Hi ,
Go to the control Panel and disable the firewall to no.
Did you add the DNS and the Gateway if not kindly add.
Posted on Jan 13, 2010
Anonymous
SOURCE: hard disk replacement for lacie ethernet disk mini 250 gb
I managed to fix mine with a little bit of work.
This website has a readme file that specifies the partitions. You must be using Linux.
http://gpl.nas-central.org/LACIE/ethernet_disk_mini_v2_-_ethernet_big_disk/EDmini_v2_partition_images/Readme
1. Plug the drive in a Linux computer, or use a Linux Live disk.
2. Create all the partitions according to the readme file. Use extended partition for the first "container". Linux Swap for the second partition. Use Ext3 format for the remaining.
3. Extract all the SDA6-8 files with bzip.
4. Use "dd" command to write those images to partitions sda6 - sda8 which you just created with this command: dd if=/dev/home/ubuntu/sda6 of=/dev/sda6 bs=512
5. Substitude /home/ubuntu above for the location where you placed the image files.
6. Once all 3 images have been written, the drive should be good to go. Put it back in the edmini, start it up and see if the website comes up. You may have the "format" the drive from the admin utility once its up and going.
Hope this helps.
use the "dd" command in
Posted on Mar 17, 2010
Anonymous
SOURCE: Lacie NAS doesn't appear in network
Have you installed the lacie network assistant?
Posted on Sep 17, 2010
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I formatted the hard drive connecting it directly to the computer (using Windows XP). Then when i reassemble the Ethernet Big Disk, it turned on but it doesn't do anything. My question is: Is the...
the OS of the Ethernet Big disk is on the hard drives, so you did erase them. This unit should only be formatted using the administration page drive format option.
LaCie usually does not give away the OS, so your option would be to close some other Ethernet Big Disk or Ethernet Disk Mini drives unto your now formatted drives.
Regards,
Jan 05, 2011 | LaCie (300966U) 1024 GB Hard Drive
Jan 23, 2010 | LaCie Ethernet Disk (300788) 1000 GB...
Lacie ED mini v2 won't start up.
I had the same problem twice, but it was the power adapters each time that were causing the problem. It wasn't the unit itself. Lacie replaced the power adapters and it worked fine.
Nov 08, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
My Lacie just quit working
Please reinstal the your operating system with drivers
Jul 05, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lost Connection
Most problems I have had with Lacie NAS have been due to duff power supplies. Seems odd that it should make a difference but it does: the power supply seems to make hte connection hang which  you then can't reset just by turning off hte power.
Apr 28, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Unable to locate Lacie Ethernet Disk Mini on the network
Lacie's out to lunch..you may be experiencing the old drivers are shot issues..get em from the main site, and reinstall, ok?
Mar 24, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Hard drive won't start up at all
Knowing LaCie the drive might need to be connected to a computer, or need a new battery.  If it is not the battery, try connecting the drive to your computer via ethernet or USB  and you might be able to get the data off of it
Jan 02, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Computers & Internet Logo
113 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
